I would like to limit access to parts of my Freedombox. I don’t want most of the Freedombox to be visible except from a few local IPs. Users anywhere should be able to log in to the individual webclients (like Roundcube), but I don’t want it to be possible to administer the Freedombox remotely, for instance.
Normally I’d do this using Apache’s access control functionality, with something like
<Directory "/plinth">
Require all denied
</Directory>
<Directory "/roundcube">
Require all granted
</Directory>
…or “Require ip [ipaddress]” or some such. But when I add a conf file with some access restrictions to the Apache server, it does not have the desired effect.
I can restrict and permit subdirectories with URL paths which I just made up (they will return either a 404 “not found” or a 403 “forbidden” error, depending on the restrictions I set). But at least many of the URL paths that the Freedombox actually uses can’t be restricted/permitted in this way (I can’t find a list of these paths; I’m sure it depends on what packages I enable). I assume my “Require” settings are overridden somewhere else, but I can’t find where.
I’m not attached to using any method here. For instance, perhaps I could rewrite some of the URLs to redirect requests to error pages? Suggestions welcome.
