Solution
Refer to this post for instructions on invoking the addressbook applet correctly such that all of the internal links are correct and the application functions as you’d expect.
Links to the i2p addressbooks presented in the i2p addressbook application are not correct.
Master Addressbook Link Incorrect
- log in to freedombox
- click the i2p application link
- select addressbook in the “applications and configuration” section and manually change the url path to /i2p/susidns from /i2p/dns.
- Select the Master Addressbook link
I expect to see the Master Addressbook management applet.
Not Found
The requested URL was not found on this server.
Apache/2.4.56 (Debian) Server at hostname.redacted Port 443
Private Addressbook Link Incorrect
- Select the Private Addressbook link
I expect to see the Private Addressbook management applet.
Not Found
Router Addressbook Link Incorrect
- Select the Router Addressbook link
I expect to see the Router Addressbook management applet.
Not Found
Published Addressbook Link Incorrect
- Select the Published Addressbook link
I expect to see the Published Addressbook management applet.
Not Found
Subscriptions Link Incorrect
- Select the Subscriptions link
I expect to see the Subscriptions management applet.
Not Found
- FreedomBox version: You are running Debian GNU/Linux 11 (bullseye) and FreedomBox version 23.6. FreedomBox is up to date.
- Hardware: Supermicro A2SDi-2C-HLN4F board with Intel Atom C3338, intel chipset
- How did you install FreedomBox?: DEBIAN_FRONTEND=noninteractive apt-get install -y freedombox
