I ran apt dist-upgrade (which seemed to complete normally) and then rebooted. Freedombox restarts and I know, for example, that Privoxy is running. Looks like syncthing is also up as is SSH.
However, still no response from plinth; still getting 503 Service Unavailable.
I ran journalctl -u plinth and here’s the tail end of the log:
--- Boot e5dfbe7dd3394b338a23eea6779b6b7e --
Oct 08 21:44:52 freedombox systemd[1]: Started FreedomBox Service (Plinth).
Oct 08 21:45:32 freedombox /usr/bin/plinth[484]: AXES: BEGIN LOG
Oct 08 21:45:32 freedombox /usr/bin/plinth[484]: AXES: Using django-axes version 5.4.3
Oct 08 21:45:32 freedombox /usr/bin/plinth[484]: AXES: blocking by IP only.
Oct 08 21:45:33 freedombox /usr/bin/plinth[484]: FreedomBox Service (Plinth) version - 21.4.4
Oct 08 21:45:33 freedombox /usr/bin/plinth[484]: Script prefix - /plinth
Oct 08 21:45:35 freedombox /usr/bin/plinth[484]: Initializing apps - apache, names, avahi, storage, backups, cockpit, firewall, config, datetime, diagnostics, dynamicdns, first_boot, help, letsencrypt, networks, power, security, snapshot, ssh, sso, upgrades, users, api, bepasty, bind, calibre, coturn, deluge, ejabberd, gitweb, i2p, ikiwiki, infinoted, jsxc, matrixsynapse, mediawiki, minetest, minidlna, mldonkey, monkeysphere, mumble, openvpn, pagekite, performance, privoxy, quassel, radicale, roundcube, samba, searx, shadowsocks, sharing, syncthing, tor, transmission, ttrss, wireguard, zoph
Oct 08 21:45:36 freedombox /usr/bin/plinth[484]: Added domain freedombox.local of type domain-type-local with services __all__
Oct 08 21:45:37 freedombox /usr/bin/plinth[484]: Added domain syncpoint.sds-ip.de of type domain-type-static with services __all__
Oct 08 21:45:38 freedombox /usr/bin/plinth[484]: # dynamicdns status
Oct 08 21:45:38 freedombox sudo[1293]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/dynamicdns status
Oct 08 21:45:38 freedombox sudo[1293]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:45:39 freedombox sudo[1293]: pam_unix(sudo:session): session closed for user root
Oct 08 21:45:39 freedombox /usr/bin/plinth[484]: Added domain syncpoint.sds-ip.de of type domain-type-dynamic with services __all__
Oct 08 21:45:39 freedombox /usr/bin/plinth[484]: # dynamicdns status
Oct 08 21:45:39 freedombox sudo[1334]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/dynamicdns status
Oct 08 21:45:39 freedombox sudo[1334]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:45:39 freedombox sudo[1334]: pam_unix(sudo:session): session closed for user root
Oct 08 21:45:40 freedombox /usr/bin/plinth[484]: $ ikiwiki get-sites
Oct 08 21:45:42 freedombox /usr/bin/plinth[484]: Checking if any Let's Encrypt certificates got renewed.
Oct 08 21:45:42 freedombox /usr/bin/plinth[484]: # letsencrypt get-status
Oct 08 21:45:43 freedombox sudo[1397]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/letsencrypt get-status
Oct 08 21:45:43 freedombox sudo[1397]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:45:54 freedombox sudo[1397]: pam_unix(sudo:session): session closed for user root
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: Certificate for syncpoint.sds-ip.de is already the latest known.
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: Running regular setup.
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: # packages is-package-manager-busy
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: Started new thread for glib main loop.
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: Setting up CherryPy server
Oct 08 21:45:54 freedombox /usr/bin/plinth[484]: Creating network manager client
Oct 08 21:45:55 freedombox sudo[1420]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/packages is-package-manager-busy
Oct 08 21:45:55 freedombox sudo[1420]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: D-Bus connection acquired: org.freedombox.Service
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: D-Bus name acquired: org.freedombox.Service
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: Created Network manager client
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Listening for SIGTERM.
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Listening for SIGHUP.
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Listening for SIGUSR1.
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Bus STARTING
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Started monitor thread '_TimeoutMonitor'.
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Serving on http://127.0.0.1:8000
Oct 08 21:45:55 freedombox /usr/bin/plinth[484]: [08/Oct/2021:21:45:55] ENGINE Bus STARTED
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: New filesystem found: by-uuid-325f972e-bb64-4f1c-94c6-b677f6bd5ed7 /dev/sda
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: Ignoring auto-mount on already mounted device: by-uuid-325f972e-bb64-4f1c-94c6-b677f6bd5ed7 /dev/sda
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: New filesystem found: by-uuid-b1142e7e-bec6-4434-8e1d-cfd44028d2d3 /dev/mmcblk0p1
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: Ignoring auto-mount on already mounted device: by-uuid-b1142e7e-bec6-4434-8e1d-cfd44028d2d3 /dev/mmcblk0p1
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: New filesystem found: by-uuid-0efefc91-94b3-4753-9d0b-88cf073d7a1d /dev/mmcblk0p2
Oct 08 21:45:56 freedombox /usr/bin/plinth[484]: Ignoring auto-mount on already mounted device: by-uuid-0efefc91-94b3-4753-9d0b-88cf073d7a1d /dev/mmcblk0p2
Oct 08 21:45:57 freedombox sudo[1420]: pam_unix(sudo:session): session closed for user root
Oct 08 21:45:57 freedombox /usr/bin/plinth[484]: Running setup for modules, essential - True, selected modules - None
Oct 08 21:45:57 freedombox /usr/bin/plinth[484]: Setup thread finished.
Oct 08 21:46:51 freedombox /usr/bin/plinth[484]: # users get-user-groups admintx
Oct 08 21:46:51 freedombox sudo[1478]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/users get-user-groups admintx
Oct 08 21:46:51 freedombox sudo[1478]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:46:53 freedombox ldapsearch[1519]: DIGEST-MD5 common mech free
Oct 08 21:46:53 freedombox ldapsearch[1525]: DIGEST-MD5 common mech free
Oct 08 21:46:53 freedombox ldapsearch[1535]: DIGEST-MD5 common mech free
Oct 08 21:46:53 freedombox ldapsearch[1545]: DIGEST-MD5 common mech free
Oct 08 21:46:54 freedombox ldapsearch[1567]: DIGEST-MD5 common mech free
Oct 08 21:46:54 freedombox sudo[1478]: pam_unix(sudo:session): session closed for user root
Oct 08 21:47:49 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:47:49 freedombox sudo[1642]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:47:50 freedombox sudo[1642]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:47:51 freedombox sudo[1642]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:00 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:00 freedombox sudo[2038]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:00 freedombox sudo[2038]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:01 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:01 freedombox sudo[2039]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:01 freedombox sudo[2039]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:01 freedombox sudo[2042]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:01 freedombox sudo[2042]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:02 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:03 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:03 freedombox sudo[2051]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:03 freedombox sudo[2051]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:03 freedombox sudo[2052]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:03 freedombox sudo[2053]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:03 freedombox sudo[2053]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:03 freedombox sudo[2052]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:03 freedombox sudo[2039]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:04 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:04 freedombox sudo[2060]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:04 freedombox sudo[2060]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:04 freedombox sudo[2038]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:05 freedombox sudo[2042]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:06 freedombox sudo[2051]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:06 freedombox sudo[2053]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:07 freedombox sudo[2052]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:07 freedombox sudo[2060]: pam_unix(sudo:session): session closed for user root
Oct 08 21:56:08 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:08 freedombox sudo[2063]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 21:56:08 freedombox sudo[2063]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 21:56:10 freedombox sudo[2063]: pam_unix(sudo:session): session closed for user root
Oct 08 22:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 08 22:45:36 freedombox sudo[3821]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 08 22:45:36 freedombox sudo[3821]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 22:45:38 freedombox sudo[3821]: pam_unix(sudo:session): session closed for user root
Oct 08 22:52:39 freedombox /usr/bin/plinth[484]: # users get-user-groups admintx
Oct 08 22:52:39 freedombox sudo[3944]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/users get-user-groups admintx
Oct 08 22:52:39 freedombox sudo[3944]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 22:52:41 freedombox ldapsearch[3989]: DIGEST-MD5 common mech free
Oct 08 22:52:41 freedombox ldapsearch[3994]: DIGEST-MD5 common mech free
Oct 08 22:52:41 freedombox ldapsearch[4004]: DIGEST-MD5 common mech free
Oct 08 22:52:41 freedombox ldapsearch[4014]: DIGEST-MD5 common mech free
Oct 08 22:52:41 freedombox ldapsearch[4030]: DIGEST-MD5 common mech free
Oct 08 22:52:42 freedombox sudo[3944]: pam_unix(sudo:session): session closed for user root
Oct 08 22:52:47 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 22:52:47 freedombox sudo[4037]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 22:52:47 freedombox sudo[4037]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 22:52:49 freedombox sudo[4037]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:32 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox sudo[4741]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox sudo[4741]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:33 freedombox sudo[4744]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox sudo[4744]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:33 freedombox sudo[4745]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox sudo[4745]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:33 freedombox sudo[4746]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:33 freedombox sudo[4746]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:36 freedombox sudo[4741]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:36 freedombox sudo[4744]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:36 freedombox /usr/bin/plinth[484]: # auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:36 freedombox sudo[4745]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:36 freedombox sudo[4746]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:36 freedombox sudo[4753]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:36 freedombox sudo[4753]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:36 freedombox sudo[4756]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:36 freedombox sudo[4756]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:37 freedombox sudo[4757]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/auth-pubtkt generate-ticket --uid admintx --private-key-file /etc/apache2/auth-pubtkt-keys/privkey.pem --tokens admin
Oct 08 23:23:37 freedombox sudo[4757]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:23:39 freedombox sudo[4753]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:39 freedombox sudo[4757]: pam_unix(sudo:session): session closed for user root
Oct 08 23:23:39 freedombox sudo[4756]: pam_unix(sudo:session): session closed for user root
Oct 08 23:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 08 23:45:36 freedombox sudo[5395]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 08 23:45:36 freedombox sudo[5395]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 08 23:45:38 freedombox sudo[5395]: pam_unix(sudo:session): session closed for user root
Oct 09 00:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 00:45:36 freedombox sudo[6836]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 00:45:36 freedombox sudo[6836]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 00:45:37 freedombox sudo[6836]: pam_unix(sudo:session): session closed for user root
Oct 09 01:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 01:45:36 freedombox sudo[8096]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 01:45:36 freedombox sudo[8096]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 01:45:37 freedombox sudo[8096]: pam_unix(sudo:session): session closed for user root
Oct 09 02:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 02:45:36 freedombox sudo[9353]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 02:45:36 freedombox sudo[9353]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 02:45:37 freedombox sudo[9353]: pam_unix(sudo:session): session closed for user root
Oct 09 03:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 03:45:36 freedombox sudo[10602]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 03:45:36 freedombox sudo[10602]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 03:45:37 freedombox sudo[10602]: pam_unix(sudo:session): session closed for user root
Oct 09 04:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 04:45:36 freedombox sudo[11911]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 04:45:36 freedombox sudo[11911]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 04:45:38 freedombox sudo[11911]: pam_unix(sudo:session): session closed for user root
Oct 09 05:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 05:45:36 freedombox sudo[13180]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 05:45:36 freedombox sudo[13180]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 05:45:38 freedombox sudo[13180]: pam_unix(sudo:session): session closed for user root
Oct 09 06:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 06:45:37 freedombox sudo[14623]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 06:45:37 freedombox sudo[14623]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 06:45:38 freedombox sudo[14623]: pam_unix(sudo:session): session closed for user root
Oct 09 07:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 07:45:37 freedombox sudo[15933]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 07:45:37 freedombox sudo[15933]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 07:45:38 freedombox sudo[15933]: pam_unix(sudo:session): session closed for user root
Oct 09 08:45:36 freedombox /usr/bin/plinth[484]: # storage usage-info
Oct 09 08:45:37 freedombox sudo[17195]: plinth : PWD=/ ; USER=root ; COMMAND=/usr/share/plinth/actions/storage usage-info
Oct 09 08:45:37 freedombox sudo[17195]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=113)
Oct 09 08:45:38 freedombox sudo[17195]: pam_unix(sudo:session): session closed for user root
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Caught signal SIGTERM.
Oct 09 09:21:53 freedombox systemd[1]: Stopping FreedomBox Service (Plinth)...
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Bus STOPPING
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE HTTP Server cherrypy._cpwsgi_server.CPWSGIServer(('127.0.0.1', 8000)) shut down
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: Exiting glib main loop
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Stopped thread '_TimeoutMonitor'.
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: Glib main loop thread exited.
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Bus STOPPED
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Bus EXITING
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Bus EXITED
Oct 09 09:21:53 freedombox /usr/bin/plinth[484]: [09/Oct/2021:09:21:53] ENGINE Waiting for child threads to terminate...
Oct 09 09:21:54 freedombox systemd[1]: plinth.service: Succeeded.
Oct 09 09:21:54 freedombox systemd[1]: Stopped FreedomBox Service (Plinth).
Oct 09 09:21:54 freedombox systemd[1]: plinth.service: Consumed 7min 4.215s CPU time.
