[SOLVED] plinth.service and many others are masked
After an upgrade
sshd|plinth|fail2ban services are unavailable.
On https://freedombox/_cockpit/system/services at many processes:
Unit plinth.service is masked.
sshd.service is masked.
Failed to restart fail2ban.service: Unit fail2ban.service is masked.
Using https://freedombox/_cockpit/system/terminal
ournalctl -b 0 -u plinth have no data and systemctl unmask|enable|start commands have no desired result
As @Sunil revealed in a topic before
‘freedombox’ package can be removed during the upgrade process
The solution
apt install freedombox
Similar cases
How did the upgrade happen, manually or automatically? If manually, was it through the FreedomBox interface, or command line?
Manually using apt
