Outside local network, audio and video calls cant get through to any xmpp clients.
If anyone has managed to get coturn working (or found any other solution) to have audio / video calls work outside of their local network, I’d really appreciate to know how they solved it.
For anyone following this; once coturn is removed (deactivated) please also do not forget to:
a. disable Automatically manage audio/video call setup in ejabberd configuration under plinth
b. run cockpit and activate ‘coturn-freedombox’ service in networking > firewall settings
c. if you have a router/modem make sure relevant ports are forwarded
d. I’m sharing my config below:
I have the same problem.
Can someone please confirm that using domain from freedombox.rocks means that Xmpp calls don’t work outside the home network?
It might be a long shot, but it has suspiciously common similarities with my post about TTRSS. There picking the second option (although the same) made it work. In plinth → apps → coturn I get the same two choices, but in this case picking the second option results to
I can confirm that ejabberd works outside the local network while using domain from ‘fbx.one’. Text, voice, and video work well. FreedomBox is exposed to internet via DMZ, and Coturn is running. So, if you are still having issues, I would check what ports are open at your router and where they are being directed within your network.
Thank you for your confirmation.
I have checked that all the necessary ports in my router for both ejabberd and coturn, but the issue still remains.
Every time I try to make a call outside the network. The recipients client rings but after a few second of “connecting” status, I get a message about “Connection Error”
Is there anyway I can get a log file?
Just in case: in my ejabberd.yml file that service for STUN is missing. There is no TCP, only UDP. This matches the data reported for Coturn in Plinth, which does not specify its required protocols, though it does for TURN.
I don’t know if this silently restricts STUN’s capability or obstructs its operation. I have not modified the default configuration of that file. I have not yet been able to test whether AV works. I run FredomBox 25.9.3 on Debian 13.
My initial post does go back some time and it has mistakes. Back then i was stumbling to try to get it to work.
Can’t say I’m “pro” now, but the configuration I’m using has turned out as below.
Some keypoints:
this configuration breaks FBX bosh
you need to create an upload folder /var/www/upload and give ownership to ejabberd
im using a static ip and own a domain name
i had to manually adjust my firewall and router port forward settings
the developers of ejabberd (process-one) have a nice mini-blog on how to tweak things. the series begin here. It’s worth taking a look at especially for configuring your dns settings.
adjust your_domain_name / your_static_ip / your_secret_key as necessary
### ejabberd configuration file
### The parameters used in this configuration file are explained at
### https://docs.ejabberd.im/admin/configuration
### The configuration file is written in YAML.
### ******* !!! WARNING !!! *******
### ******* YAML IS INDENTATION SENSITIVE *******
### ******* MAKE SURE YOU INDENT SECTIONS CORRECTLY *******
### Refer to http://en.wikipedia.org/wiki/YAML for the brief description.
# loglevel: Verbosity of log files generated by ejabberd
loglevel: info
# rotation: Disable ejabberd's internal log rotation, as the Debian package
# uses logrotate(8).
log_rotate_count: 0
# hosts: Domains served by ejabberd.
# You can define one or several, for example:
# hosts:
# - "example.net"
# - "example.com"
# - "example.org"
hosts:
- "_your_domain_name_"
certfiles:
- "/etc/ejabberd/ejabberd.pem"
# - /etc/letsencrypt/live/localhost/fullchain.pem
# - /etc/letsencrypt/live/localhost/privkey.pem
# TLS configuration
define_macro:
'TLS_CIPHERS': "HIGH:!aNULL:!eNULL:!3DES:@STRENGTH"
'TLS_OPTIONS':
- "no_sslv3"
- "no_tlsv1"
- "no_tlsv1_1"
- "cipher_server_preference"
- "no_compression"
# 'DH_FILE': "/path/to/dhparams.pem"
# generated with: openssl dhparam -out dhparams.pem 2048
c2s_ciphers: 'TLS_CIPHERS'
s2s_ciphers: 'TLS_CIPHERS'
c2s_protocol_options: 'TLS_OPTIONS'
s2s_protocol_options: 'TLS_OPTIONS'
# c2s_dhfile: 'DH_FILE'
# s2s_dhfile: 'DH_FILE'
listen:
- port: 5222
ip: "::"
module: ejabberd_c2s
max_stanza_size: 262144
shaper: c2s_shaper
access: c2s
starttls_required: true
- port: 5223
ip: "::"
shaper: c2s_shaper
access: c2s
tls: false
- port: 5269
ip: "::"
module: ejabberd_s2s_in
max_stanza_size: 524288
- port: 5443
ip: "::"
module: ejabberd_http
tls: true
request_handlers:
/api: mod_http_api
/bosh: mod_bosh
## /captcha: ejabberd_captcha
/upload: mod_http_upload
/ws: ejabberd_http_ws
- port: 5280
ip: "::"
tls: false
request_handlers:
/admin: ejabberd_web_admin
/.well-known/acme-challenge: ejabberd_acme
/mqtt: mod_mqtt
- port: 1883
ip: "::"
module: mod_mqtt
backlog: 1000
- port: 8883
ip: "::"
module: mod_mqtt
backlog: 1000
tls: true
- port: 5349
transport: tcp
module: ejabberd_stun
use_turn: true
tls: true
turn_min_port: 49152
turn_max_port: 65535
ip: "::"
turn_ip: _your_static_ip
## Disabling digest-md5 SASL authentication. digest-md5 requires plain-text
## password storage (see auth_password_format option).
disable_sasl_mechanisms:
- "digest-md5"
- "X-OAUTH2"
s2s_use_starttls: required
## Store the plain passwords or hashed for SCRAM:
auth_password_format: scram
## Full path to a script that generates the image.
## captcha_cmd: "/usr/share/ejabberd/captcha.sh"
acl:
admin:
user:
local:
user_regexp: ""
loopback:
ip:
- 127.0.0.0/8
- ::1/128
access_rules:
local:
allow: local
c2s:
deny: blocked
allow: all
announce:
allow: admin
configure:
allow: admin
muc_create:
allow: local
pubsub_createnode:
allow: local
trusted_network:
allow: loopback
api_permissions:
"console commands":
- ejabberd_ctl
who: all
what: "*"
"admin access":
who:
access:
allow:
- acl: loopback
- acl: admin
oauth:
scope: "ejabberd:admin"
access:
allow:
- acl: loopback
- acl: admin
what:
- "!stop"
- "!start"
"public commands":
who:
ip: 127.0.0.1/8
what:
- status
- connected_users_number
shaper:
normal:
rate: 3000
burst_size: 20000
fast: 200000
shaper_rules:
max_user_sessions: 10
max_user_offline_messages:
5000: admin
100: all
c2s_shaper:
none: admin
normal: all
s2s_shaper: fast
modules:
mod_adhoc: {}
mod_admin_extra: {}
mod_announce:
access: announce
mod_avatar: {}
mod_blocking: {}
mod_bosh: {}
mod_caps: {}
mod_carboncopy: {}
mod_client_state: {}
mod_configure: {}
## mod_delegation: {} # for xep0356
mod_disco: {}
mod_fail2ban: {}
mod_http_api: {}
mod_http_upload:
put_url: https://@HOST@:5443/upload
docroot: /var/www/upload
custom_headers:
"Access-Control-Allow-Origin": "https://@HOST@"
"Access-Control-Allow-Methods": "GET,HEAD,PUT,OPTIONS"
"Access-Control-Allow-Headers": "Content-Type"
mod_last: {}
mod_mam:
assume_mam_usage: false
default: always
cache_life_time: 3600
cache_size: 1000
db_type: mnesia
request_activates_archiving: false
## ## Mnesia is limited to 2GB, better to use an SQL backend
## ## For small servers SQLite is a good fit and is very easy
## ## to configure. Uncomment this when you have SQL configured:
## ## db_type: sql
## assume_mam_usage: false
## default: always
mod_mqtt: {}
mod_muc:
access:
- allow
access_admin:
- allow: admin
access_create: muc_create
access_persistent: muc_create
access_mam:
- allow
default_room_options:
mam: true
mod_muc_admin: {}
mod_offline:
access_max_user_messages: max_user_offline_messages
mod_ping: {}
mod_pres_counter:
count: 5
interval: 60
mod_privacy: {}
mod_private: {}
mod_pubsub:
access_createnode: pubsub_createnode
plugins:
- flat
- pep
force_node_config:
"eu.siacs.conversations.axolotl.*":
access_model: open
## Avoid buggy clients to make their bookmarks public
storage:bookmarks:
access_model: whitelist
mod_push: {}
mod_push_keepalive: {}
## mod_register:
## ## Only accept registration requests from the "trusted"
## ## network (see access_rules section above).
## ## Think twice before enabling registration from any
## ## address. See the Jabber SPAM Manifesto for details:
## ## https://github.com/ge0rg/jabber-spam-fighting-manifesto
## ip_access: trusted_network
mod_roster:
versioning: true
mod_s2s_dialback: {}
mod_shared_roster: {}
mod_sic: {}
mod_stream_mgmt:
resend_on_timeout: if_offline
mod_stun_disco:
credentials_lifetime: 1000d
secret: _your_secret_key
services:
- host: _your_domain_name
port: 3478
type: stun
transport: udp
port: 3478
type: turn
transport: udp
port: 5349
type: stuns
transport: tcp
port: 5349
type: turns
transport: tcp
mod_vcard:
search: false
mod_vcard_xupdate: {}
mod_version: {}
auth_method: ldap
ldap_servers:
- "localhost"
ldap_base: "ou=users,dc=thisbox"
### Local Variables:
### mode: yaml
### End:
### vim: set filetype=yaml tabstop=8
s2s_certfile: "/etc/ejabberd/letsencrypt/_your_domain_name/ejabberd.pem"
Over the past years, i have come to say that serving xmpp is not for the very faint-hearted. But when i look at the freedom, privacy and functions it presents, i think its very underrated.
I hope you like it as much as i do.
