FreedomBox 22.19 has been released and uploaded to Debian unstable.
Migration to testing is temporarily on hold due to a bug in another package. (The maintainer plans to upload a fix for the bug soon.)
Highlights
- jsxc: Allow disabling the app
- app: Add a menu item to trigger uninstallation
- Note: Uninstalling an app is an experimental feature at this time.
Other Changes
- app: Add API to uninstall an app
- avahi: Don’t disable after tests
- backups: Use AppView for the main app page
- container: Display help message when no args are passed
- container: Show default values in command help
- d/control: Break ufw as we use firewalld
- debian: Update Spanish translation template
- diagnostics: Use AppView for app page
- ejabberd: Set hostname for test that relies on it
- forms: Implement form for uninstallation
- janus: Convert action to privileged
- janus: Handle upgrades to 1.0.*
- letsencrypt: Use AppView for app page
- locale: Update translations for Bulgarian, Chinese (Simplified), Czech, French, German, Spanish, Turkish, Ukrainian
- names: Use AppView for app page
- networks: Use AppView for app page
- operation: Factor out template code into a separate file
- operation: Show operations on app page in addition to setup page
- package: Implement low-level methods for uninstalling
- package: Implement uninstall in Package component
- power: Use AppView for app page
- security: Use AppView for app page
- setup: Drop check for already running operation
- setup: Implement operation to uninstall an app
- snapshot: Use AppView for app page
- tests: Make functional.is_available check faster
- tests: functional: Add install/uninstall test for all apps
- tor: Use AppView and Operation for app page
- ttrss: Add donation url
- upgrades: Add button to test dist-upgrade in development mode
- upgrades: Hold janus during dist-upgrade
- views: Implement a view to uninstall an app
- 109247019824
- Andrij Mizyk
- Burak Yavuz
- Eric
- Fioddor Superconcentrado
- Hugel
- James Valleroy
- Jiří Podhorecký
- Joseph Nuthalapati
- Maxime Leroy
- nautilusx
- nbenedek
- Sunil Mohan Adapa
- Veiko Aasa
