Hello,
i changed in /etc/php/8.2/fpm/php.ini according to the recommendations and it works now. Until there is a better way as a temporary workarround.
Hey, as a newbie could you help me with this!? What exactly should i change in that file? And, do you access it from SSH? I was trying to look for a way of installing LibrePhoto on to the fbx but could not find info so im gonna give Zoph a try! Thanks in advance!
Follow the Zoph link from FreedomBox with your web browser - you will get the Failed Requirements page shared by @Gareth.
Look at the requirements which refer to php.ini
Log in to FreedomBox by SSH.
As an ordinary user read the file mentioned by @MikaelB above. You’ll see configuration keys in the file which match those referred to in the Failed Requirements list. Look for the php.ini entries from Failed Requirements and find these in the configuration file. max_execution_time is an example of that.
As root you’ll need to edit that file and update the values. For example:
– find upload_max_filesize and change the value from the default 2M to the recommended 16M.
– repeat this for all of the php.ini warning or error keys in the Failed Requirements
– You won’t change the PHP version - just run with what you have. They are telling us that is working.
