I am running a Olimex Pioneer box, updated to Bullseye
I am the Administrator with administrator account. I also have my personal account.
While trying to setup a client app to access FBox services, I hit three strikes for login, and was locked out of the login interface.
It appears that it’s not account based. I am unable to login with admin credentials; in fact, I can’t even get access to the login GUI.
I’ve tried with other devices and they too are blocked from a login window.
This suggests that the block is based on a IP range.
All attempts from different browsers and machines show the following in the address bar:
https://www.mydomain.net/plinth/accounts/login/locked/?username=
What is the lockout time for this error?
Why would lockout on one account prevent me from login on a separate account?
I am able to ssh into the Fbox using Admin priveleges.
-SF
Update:
Using mybox.local I was able to login as Admin, but see no options to resolve the lockout issue, however, using the user/group panel and selecting my personal account, I saw that all previous priveleges were no longer selected.
I reselected the permissions for my personal account, logged out of the Admin account and attempted to login on my personal account thru the normal login process. I had the same results as above.
However, I could login to my personal acct using the mybox.local address.
My primary problem, web access, not local access, is still unresolved.
-SF
