Since some time I notice that the package libpam-module
s is not upgraded.
Reason is that the file /etc/security/access.conf
needs a conffile merge.
The relevant difference is that the old conffile has got the lines
# All other users should be denied to get access from all sources.
#- : ALL : ALL
-:ALL EXCEPT root fbx plinth (admin) (sudo):ALL
, while the new one just says
#-:ALL:ALL
Am I right that I can simply keep the line
from the old file? (or in fact all of the old file, because the rest is commented)
- FreedomBox version: 19.1 (from Help -> About page)
- Hardware: A20 OLinuXino LIME2
- How did you install FreedomBox?: a testing image from https://freedombox.org
