I know this is not a FBX feature, but wanting to try using rootless podman (via Debian sources), I’m having trouble.
- I’ve installed podman-cockpit via debian sources (this came with all deps including podman)
- I’ve enabled podman through cockpit
- Tried to pull images via cockpit (doesn’t work - hangs for hours)
- Tried pulling image via terminal, some blobs seem to be downloaded but process falls in to error with below output.
Error: copying system image from manifest list: writing blob: adding layer with blob "sha256:cf04c63912e16506c4413937c7f4579018e4bb25c272d989789cfba77b12f951": ApplyLayer stdout: stderr: potentially insufficient UIDs or GIDs available in user namespace (requested 0:42 for /etc/shadow): Check /etc/subuid and /etc/subgid if configured locally and run podman-system-migrate: lchown /etc/shadow: invalid argument exit status 1
I’ve done plenty of search but just cant seem to overcome the problem. Any help with those experienced would be much appreciated.
Thanks in advance.
P.S.
podman system migratedoesn’t seem to solve the issue.sudodoes the trick but prefer using podman without root
