Using bepasty with non-web clients (pastebinit)
Bepasty is an awesome way to share files using the browser.
Another way to access bepasty is from terminal using pastebinit.
Bepasty project support this method as it is included in the official documentation.
Unfortunately I cannot make it work on Freedombox.
When I try to upload a file using the above method. I gen an error:
Failed to contact the server: HTTP Error 405: METHOD NOT ALLOWED
Steps to Reproduce (in my personal Computer)
  1. create file ~/.pastebinit.xml:
<pastebinit>
    <pastebin>https://myfboxdomain.org/bepasty</pastebin>
    <format></format>
</pastebinit>
  1. create file ~/.pastebin.d/bepasty.conf:
[pastebin]
basename = myfboxdomain.com/bepasty
regexp = https://myfboxdomain.com/bepasty
[format]
content = text
title = filename
format = contenttype
page = page
password = token
[defaults]
page = +upload
  1. run the command:
    pastebinit -t example.txt -p yourpassword -i example.txt
where yourpassword is the admin password from myfboxdomain.com/apps/bepasty
terminal must return me an upload url and actually upload the file
  • FreedomBox version: 24.8
  • Hardware: Freedombox Pioneer
P.S.: If there is another cli method that a dev/user is using successfully please let me know.
This very likely due to insufficient Apache configuration. I have created an issue to track this.
Try with the following configuration:
[pastebin]
post_page = +upload
[format]
content = text
title = filename
password = token
[defaults]
I can upload files using curl (all on one line):
curl --insecure -F "file=@${FILENAME}" https://user:${PASSWORD}@${HOSTNAME}/bepasty/+upload -X POST
Where ${FILENAME} is the path/filename in the local filesystem, ${PASSWORD} is a bepasty password with write permissions configured on the freedombox, and ${HOSTNAME} is the freedombox hostname.
I used --insecure to disable curl’s certificate validation because my freedombox currently has a self-signed certificate (this option is not recommended - see the warning in curl - SSL CA Certificates).
I notice in /.pastebinit.xml
And in be pasty.conf
It may be the top level domains don’t match?
