Using api from Urbackup
Goodday i’m verry impressed with FreedomBox, although it is not an easy task to get it all working properly.
my guestion is has someone experience with integrating the Urbackup api in FreedomBox and how dit you got it to work, i regret that it seems that i cant integrate these Urbackup into FreedomBox in one simple way, or maybe one of you can put me on track to use a even good piece of software that i can integrate in an easy way. i need to give people outsite of my own network an easy to use possibillity to backup there stuff on my own backup options.
thanks in advance,
Paul Moolenaar (in the Netherlands)
