Hi, this is my first post and I’ve had a FreedomBox for less than 12 hours, I hope this post is OK anyway!
I’m not sure what I’ve done but I’m also curious about how users on the UI and users on the machine itself relate to each other. Is there a way to solve this? After having messed this up, I’ve since learned that y’all want the UI to be the ultimate way people interact with FreedomBox. I’m not sure I dig that, but anyway. I’m just confused by the following behavior:
Problem Description and how to Reproduce
I can log into the UI using user: user01-admin
or I can ssh into the machine using user01@192...
(without the -admin
part)
When I go to Users and Groups through the UI, user01-admin
is the only listed user. When I click on it, do nothing, and then clicks Save Changes
, I’m given 2 red and 1 green messages:
Failed to add user to group.
Unable to set SSH keys.
User user01-admin updated.
Other notes
- I think
user-01
was the original username I typed in at the very beginning, and i used the UI to change that touser10-admin
- Through SSH I did
adduser helloworld
andusermod -a -G sudo helloworld
- I discovered this issue while trying to add my public key to
user01-admin
through the UI - If I run
getent passwd | awk -F: '{ print $1}'
I seehelloworld
anduser01
but notuser01-admin
Just the success message
And I guess more overlap between users according to the OS and “users” on plinth, I would have expected something adduser helloworld
to result in a new user in the UI
Those 2 error messages
Debian GNU/Linux 10 (buster) and FreedomBox version 20.8. FreedomBox is up to date,
I ordered the hardware yestersday and got it today (nice!)
