Hello I’m trying setup ejabberd server , use a client
Can someone help me with stupid questions ?
I have allready a domainname for my freedombox (raspi4 via Debian), and a cerificate
Ports are open in the router for ejabberd
First:
is the domainname of the freedombox automatically linked to ejabberd and let’s Encrypted?
(the manual says something about this but I don’t find that anywhere)
I don’t understand how to use a client.
JSXC for example:
asked for domain , login and pasword
when I put my domainname there is an error BOSH server NOT reachable or misconfigured.
(I don’t read anything from a BOSCH server anywhere)
Conversation mobile for example: is asking for xmpp addres and a password
I don’t now what which address they mean. It is in the email-form I read . username@hostname
But that doesnt work.
When put username@domainname.freedombox.rocks it won’t work
username is my username in my freedombox
Can someone put me in the right direction please ?
Since the last update conversations doesn’t accept self signed certificates, if I understand that right. I struggle myself to get a let’s encrypt certificate for ejabberd. I created a new topic.
Please tell, if you found a viable solution.
I have a Let’s encrypt certificate that I obtained by the “Let’s encrypt” option in the system menu. I know it is used by the web interface but I am not sure how to see whether it is used by ejabberd or not.
I am using the latest version of conversations from F-Droid (2.9.13+fcr) and Gajim 1.3.2 and both work, but I don’t know how to check the TLS certificate of the server.
I don’t have that error. The hashes are the same like the ones visible in my web browser for the web interface. I tried to look at configuration files, ejabberd.yml refers to a .pem file in a letsencrypt subdir of ejabberd, I guess apache uses another file but I am unable to find that now.
I only used the plinth interface to configure things, except perhaps an apt update/upgrade once at the very beginning (I have the Pioneer edition and have used the default sdcard image).
I can check files on my Feedombox to compare with your setup if you know what to look for.
