Is’t the actual version of FreedomBox 20.13? My one is still 20.12.2 and I suspect something is wrong. Some days ago i used a snapshot for a rollback and in the list of snapshots is a message: will be used at next boot… can this have an effect on the updates?
Freedombox works normally except problems with Matrix Synapse/Coturn since the transition from Riot to Element.
I tried a update manually and got some errors:
sudo apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following packages have been kept back:
matrix-synapse
The following packages will be upgraded:
ca-certificates
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 158 kB of archives.
After this operation, 3072 B disk space will be freed.
Do you want to continue? [Y/n]
Get:1 Index of /debian stable-updates/main armhf ca-certificates all 20200601~deb10u1 [158 kB]
Fetched 158 kB in 0s (664 kB/s)
Failed to set locale. Fix your system.
quota not working (qgroup not set)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = “de_DE.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Preconfiguring packages …
(Reading database … 107430 files and directories currently installed.)
Preparing to unpack …/ca-certificates_20200601~deb10u1_all.deb …
Unpacking ca-certificates (20200601~deb10u1) over (20190110) …
Setting up ca-certificates (20200601~deb10u1) …
Updating certificates in /etc/ssl/certs…
13 added, 15 removed; done.
Processing triggers for ca-certificates (20200601~deb10u1) …
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…
done.
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
Scanning processes…
Scanning linux images…Running kernel seems to be up-to-date.
Failed to check for processor microcode upgrades.
No services need to be restarted.
No containers need to be restarted.
No user sessions are running outdated binaries.
Maybe i have to reinstall the Freedombox?
FreedomBox is plugged into a router
I bought my kit July 2019
The version of FreedomBox 20.12.1.
