Along with the upgrade to Bookworm, Postgresql was upgraded from version 13 to 15. As it turned out, I was still running version 11 from Buster! As I didn’t realize it at the time I manually finished the upgrade I allowed version 11 to be removed. Well, I installed the packages manually and tt-rss
works fine with it.
I decided to try to migrate the database to version 15 using the following command run from /tmp
sudo -H -u postgres /usr/lib/postgresql/15/bin/pg_upgrade \
-b /usr/lib/postgresql/11/bin \
-B /usr/lib/postgresql/15/bin \
-d /var/lib/postgresql/11/main \
-D /var/lib/postgresql/15/main \
-o ' -c config_file=/etc/postgresql/11/main/postgresql.conf' \
-O ' -c config_file=/etc/postgresql/15/main/postgresql.conf'
This command is a modified version of that shown on the Postgresql Wiki and referenced from the Debian Wiki.
The command appears to have been successful:
Performing Consistency Checks
Checking cluster versions ok
Checking database user is the install user ok
Checking database connection settings ok
Checking for prepared transactions ok
Checking for system-defined composite types in user tables ok
Checking for reg* data types in user tables ok
Checking for contrib/isn with bigint-passing mismatch ok
Checking for user-defined encoding conversions ok
Checking for user-defined postfix operators ok
Checking for incompatible polymorphic functions ok
Checking for tables WITH OIDS ok
Checking for invalid "sql_identifier" user columns ok
Creating dump of global objects ok
Creating dump of database schemas
ok
Checking for presence of required libraries ok
Checking for new cluster tablespace directories ok
If pg_upgrade fails after this point, you must re-initdb the
new cluster before continuing.
Performing Upgrade
Analyzing all rows in the new cluster ok
Freezing all rows in the new cluster ok
Deleting files from new pg_xact ok
Copying old pg_xact to new server ok
Setting oldest XID for new cluster ok
Setting next transaction ID and epoch for new cluster ok
Deleting files from new pg_multixact/offsets ok
Copying old pg_multixact/offsets to new server ok
Deleting files from new pg_multixact/members ok
Copying old pg_multixact/members to new server ok
Setting next multixact ID and offset for new cluster ok
Resetting WAL archives ok
Setting frozenxid and minmxid counters in new cluster ok
Restoring global objects in the new cluster ok
Restoring database schemas in the new cluster
ok
Copying user relation files
ok
Setting next OID for new cluster ok
Sync data directory to disk ok
Creating script to delete old cluster ok
Checking for extension updates ok
Upgrade Complete
Optimizer statistics are not transferred by pg_upgrade.
Once you start the new server, consider running:
/usr/lib/postgresql/15/bin/vacuumdb --all --analyze-in-stages
Running this script will delete the old cluster's data files:
./delete_old_cluster.sh
Also from /tmp
ran the following:
sudo -H -u postgres /usr/lib/postgresql/15/bin/vacuumdb --all --analyze-in-stages
vacuumdb: processing database "postgres": Generating minimal optimizer statistics (1 target)
vacuumdb: processing database "template1": Generating minimal optimizer statistics (1 target)
vacuumdb: processing database "ttrss": Generating minimal optimizer statistics (1 target)
vacuumdb: processing database "postgres": Generating medium optimizer statistics (10 targets)
vacuumdb: processing database "template1": Generating medium optimizer statistics (10 targets)
vacuumdb: processing database "ttrss": Generating medium optimizer statistics (10 targets)
vacuumdb: processing database "postgres": Generating default (full) optimizer statistics
vacuumdb: processing database "template1": Generating default (full) optimizer statistics
vacuumdb: processing database "ttrss": Generating default (full) optimizer statistics
Starting tt-rss
fails quickly:
Jun 25 20:55:33 freedombox systemd[1]: Started tt-rss.service - Update the Tiny Tiny RSS subscribed syndication feeds.
Jun 25 20:55:35 freedombox systemd[1]: tt-rss.service: Main process exited, code=exited, status=101/n/a
Jun 25 20:55:35 freedombox systemd[1]: tt-rss.service: Failed with result 'exit-code'.
Jun 25 20:55:35 freedombox systemd[1]: tt-rss.service: Consumed 1.190s CPU time.
Trying to load the tt-rss
Web page results in seeing:
connection to server at "localhost" (127.0.0.1), port 5432 failed: FATAL: password authentication failed for user "ttrss"
Now I’m a bit stumped because so far as I know, there shouldn’t have been any changes to the DB. As if to prove the point I reverted back to PG 11 and tt-rss
is working fine. My SQL is next to non-existent so any tips on what to look for in PG 15 would be appreciated.
