I installed Freedombox on a brand new Beaglebone Black C while connect via ssh:
$ sudo apt-get update
$ sudo DEBIAN_FRONTEND=noninteractive apt-get install freedombox
During installation there was an error reported with apache2 not being able to start.
After installation I rebooted and connected via ssh, and performed the following tests since I was not able to access via freedombox.local
$ sudo systemctl start apache2
Job for apache2.service failed because the control process exited with error code.
See “systemctl status apache2.service” and “journalctl -xe” for details.
$ sudo systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset:
Active: failed (Result: exit-code) since Wed 2021-02-24 20:16:50 UTC; 53s ago
Docs: Apache HTTP Server Version 2.4 Documentation - Apache HTTP Server Version 2.4
Process: 4044 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILU
Feb 24 20:16:49 beaglebone systemd[1]: Starting The Apache HTTP Server…
Feb 24 20:16:50 beaglebone apachectl[4044]: (98)Address already in use: AH00072:
Feb 24 20:16:50 beaglebone apachectl[4044]: no listening sockets available, shut
Feb 24 20:16:50 beaglebone apachectl[4044]: AH00015: Unable to open logs
Feb 24 20:16:50 beaglebone apachectl[4044]: Action ‘start’ failed.
Feb 24 20:16:50 beaglebone apachectl[4044]: The Apache error log may have more i
Feb 24 20:16:50 beaglebone systemd[1]: apache2.service: Control process exited,
Feb 24 20:16:50 beaglebone systemd[1]: apache2.service: Failed with result 'exit
Feb 24 20:16:50 beaglebone systemd[1]: Failed to start The Apache HTTP Server.
lines 1-16/16 (END)…skipping…
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Process: 4044 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Feb 24 20:16:50 beaglebone apachectl[4044]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
Feb 24 20:16:50 beaglebone apachectl[4044]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
Feb 24 20:16:50 beaglebone apachectl[4044]: no listening sockets available, shutting down
Feb 24 20:16:50 beaglebone apachectl[4044]: The Apache error log may have more information.
Feb 24 20:16:50 beaglebone systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Feb 24 20:16:50 beaglebone systemd[1]: apache2.service: Failed with result ‘exit-code’.
debian@beaglebone:~$ journalctl -xe
Feb 24 20:23:05 beaglebone systemd[1]: plinth.service: Main process exited, code=exited, status=70/SOFTWARE
– Subject: Unit process exited
– Defined-By: systemd
– Support: link removed
– An ExecStart= process belonging to unit plinth.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 70.
Feb 24 20:23:05 beaglebone sudo[4532]: pam_unix(sudo:session): session closed for user root
Feb 24 20:23:05 beaglebone systemd[1]: plinth.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– Support: (link removed)
– The unit plinth.service has entered the ‘failed’ state with result ‘exit-code’.
Feb 24 20:23:05 beaglebone systemd[1]: plinth.service: Service RestartSec=100ms expired, scheduling restart.
Feb 24 20:23:05 beaglebone systemd[1]: plinth.service: Scheduled restart job, restart counter is at 13.
– Subject: Automatic restarting of a unit has been scheduled
– Automatic restarting of the unit plinth.service has been scheduled, as the result for
– the configured Restart= setting for the unit.
Feb 24 20:23:05 beaglebone systemd[1]: Stopped FreedomBox Service (Plinth).
– Subject: A stop job for unit plinth.service has finished
– A stop job for unit plinth.service has finished.
– The job identifier is 3058 and the job result is done.
Feb 24 20:23:05 beaglebone systemd[1]: Started FreedomBox Service (Plinth).
– Subject: A start job for unit plinth.service has finished successfully
– A start job for unit plinth.service has finished successfully.
– The job identifier is 3058.
Feb 24 20:23:08 beaglebone sudo[4100]: pam_unix(sudo:session): session closed for user root
Feb 24 20:23:15 beaglebone bonescript[4523]: info: Opening port systemd to serve up /usr/share/bone101
lines 1923-1963/1963 (END)
I was not able to login to freedombox via ssh as the beaglebone shows up as beaglebone and not freedombox on my DHCP Client Table in my router.
I was hoping that it would just work as described after installation.
I am unable to access the freedombox as the freedombox. The beaglebone.local also appears to not be working now.
- FreedomBox version: from apt install (see above) from Buster Beaglebone image
- Hardware: Beaglebone Black C
- *I decided to install it since I was not able to Flash the internal EMMC directly
From searching I am under the impression that this has something to do with the apache configuration files. Perhaps since the installation was put on top of what Beaglebone had already established prior. I have been poking around the config files, but am not really sure what I am doing.
debian@beaglebone:/etc/apache2/sites-available$ sudo mv 000-default.conf 000-default.conf.bak
[sudo] password for debian:
debian@beaglebone:/etc/apache2/sites-available$ ls
000-default.conf.bak default-ssl.conf plinth.conf plinth-ssl.conf
debian@beaglebone:/etc/apache2/sites-available$ sudo mv default-ssl.conf default-ssl.conf.bak
debian@beaglebone:/etc/apache2/sites-available$ systemctl start apache2
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to start ‘apache2.service’.
Authenticating as: root
Password:
polkit-agent-helper-1: pam_authenticate failed: Authentication failure
==== AUTHENTICATION FAILED ===
Failed to start apache2.service: Access denied
See system logs and ‘systemctl status apache2.service’ for details.
debian@beaglebone:/etc/apache2/sites-available$ sudo systemctl start apache2
debian@beaglebone:/etc/apache2/sites-available$ systemctl status apache2.service
Active: failed (Result: exit-code) since Wed 2021-02-24 21:25:10 UTC; 30s ago
Docs: link
Process: 9973 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Feb 24 21:25:09 beaglebone systemd[1]: Starting The Apache HTTP Server…
Feb 24 21:25:10 beaglebone apachectl[9973]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
Feb 24 21:25:10 beaglebone apachectl[9973]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
Feb 24 21:25:10 beaglebone apachectl[9973]: no listening sockets available, shutting down
Feb 24 21:25:10 beaglebone apachectl[9973]: AH00015: Unable to open logs
Feb 24 21:25:10 beaglebone apachectl[9973]: Action ‘start’ failed.
Feb 24 21:25:10 beaglebone apachectl[9973]: The Apache error log may have more information.
Feb 24 21:25:10 beaglebone systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Feb 24 21:25:10 beaglebone systemd[1]: apache2.service: Failed with result ‘exit-code’.
Feb 24 21:25:10 beaglebone systemd[1]: Failed to start The Apache HTTP Server.
debian@beaglebone:/etc/apache2/sites-available$ grep -ri listen /etc/apache2
/etc/apache2/apache2.conf:# supposed to determine listening ports for incoming connections which can be
/etc/apache2/apache2.conf:# Include list of ports to listen on
/etc/apache2/ports.conf:Listen 80
/etc/apache2/ports.conf: Listen 443
/etc/apache2/conf-available/tahoe-plinth.conf:Listen 5678
/etc/apache2/conf-available/matrix-synapse-plinth.conf:## not useful for federation which requires SRV record or listening on port
This might be the problem!
debian@beaglebone:/etc/apache2/sites-available$ sudo lsof -i:80
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nginx 1419 root 6u IPv4 33066 0t0 TCP *:http (LISTEN)
nginx 1419 root 7u IPv6 33067 0t0 TCP *:http (LISTEN)
nginx 1420 www-data 6u IPv4 33066 0t0 TCP *:http (LISTEN)
nginx 1420 www-data 7u IPv6 33067 0t0 TCP *:http (LISTEN)
I am just not sure which one to get rid of…
Any help would be much appreciated.
