I have run the command shown below to check the log file for: transmission-daemon.
sudo journalctl -n 10 -o cat -e -u transmission-daemon
And its out put is:
Starting Transmission BitTorrent Daemon... Started Transmission BitTorrent Daemon. [2021-02-15 23:52:57.435] UDP Failed to set receive buffer: requested 4194304, got 425984 (tr-udp.c:97) [2021-02-15 23:52:57.435] UDP Failed to set send buffer: requested 1048576, got 425984 (tr-udp.c:105)
I google up this message and found, transmission-daemon: UDP Failed to set receive / send buffer From reading this article I done the following.
sudo nano /etc/sysctl.conf
And I have added the two lines below to this text file:
net.core.rmem_max = 4194304
net.core.wmem_max = 1048576
The memory amounts above are the amounts transmission was asking for. The memory amounts in the article about this issue are greater.
Then I have ran the two commands listed below to enable this change:
sudo sysctl -p
sudo sysctl --system
Then I have disable transmission from it config page in freedombox and then enable it again.
I have check to see if the messages were there or not in transmission log file.
The memory message is no longer there.
Would it be possible for this tweak to be added to the Freedombox package ? That if they are needed ?
- FreedomBox version:
Debian GNU/Linux bullseye/sid and FreedomBox version 21.2
- Hardware:
Laptop: LENOVO 0769ECG
- How did you install FreedomBox ?:
apt install freedombox on Debian testing ’ bullseye ’
Regards: peterc
