Hello All and thanks !!
I am back running debian stable freedombox. The main reason is a bug with transmission daemon 3.00-1 in debian bullseye. Which I encountered.
Below is a copy and paste from a fellow Transission user that explains the issue and blow that is a web link to his post at github transmission.
" I recently upgraded to 3.0, I am running the linuxserver.io docker but I think this is a 3.0 behaviour.
I primarily run transmission via Transmission Remote GUI but as of installing 3.0 the UI is unable to connect at all once at least one DOWNLOAD is over about 5MB/s. While I am used to the UI / API hanging during file moves I have never had a problem during downloads. This appears to be a new issue with the lack of threading.
I was able to load the built in web UI but it was INCREDIBLY slow and unresponsive as well. "
If this issue is solved will the new package be in backports for bullseye ?
Package: transmission (3.00-1) bullseye
Package: transmission (2.94-2+deb10u2) buster
Regards: peter
