Thanks for the update.
I have a question (see below) about getting an appropriate version of FB running on my box that is a balance between being stable enough to be useful, while also receiving new releases. Maybe I should start a new thread for this question?
Question
I’m running FB on a Raspberry Pi3B. I’ve been messing with my box too much and have now flattened it and I’m preparing to put a fresh install of FB on it
If I follow the instructions at the following FB Wiki link - “Upgrade FreedomBox from stable to testing” - but change testing to backports, will I end up with the backports stable version running on my box? https://wiki.debian.org/FreedomBox/QuestionsAndAnswers#Upgrade_FreedomBox_from_stable_to_testing
And will backports get the Coturn app soon (next week-ish, as you say)? While also providing a stable enough version of FB to be usable?
Or would the testing image the RPi3B from here be best? https://freedombox.org/download/raspberrypi3b+/
I’m still a bit confused about working with the versions and repos!
Thanks for all your help.
