Hello. My box is not being able to fetch available updates… The logs led me to believe that it couldn’t reach security.debian.org due to time de-synchronization. After a few unsuccessful trials of manual configuration of the box’s System time through cockpit’s ui, I made the following changes to /etc/systemd/timesyncd.conf
NTP=
FallbackNTP=0.debian.pool.ntp.org 1.debian.pool.ntp.org 2.debian.pool.ntp.org 3.debian.pool.ntp.org
RootDistanceMaxSec=30
PollIntervalMinSec=32
PollIntervalMaxSec=2048
ConnectionRetrySec=30
SaveIntervalSec=60
enabled NTP-sync
sudo timedatectl set-ntp true
and unmasked the service systemd-timesyncd
sudo systemctl unmask systemd-timesyncd
after that restarted the service systemd-timesyncd and validate it’s running
sudo systemctl restart systemd-timesyncd
systemctl status systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; preset: enabled)
Active: active (running) since Sat 2025-07-05 20:38:00 WEST; 1h 42min ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 5319 (systemd-timesyn)
Status: "Idle."
Tasks: 2 (limit: 955)
but System clock is not synchronised
$ timedatectl
Local time: Sat 2025-07-05 22:23:51 WEST
Universal time: Sat 2025-07-05 21:23:51 UTC
RTC time: n/a
Time zone: Europe/Lisbon (WEST, +0100)
System clock synchronized: no
NTP service: active
RTC in local TZ: no
PS: Since I see some weird logs like:
ERROR: INVALID_SERVICE: tor-obfs4 (I don’t have tor installed)
Object of type gaierror is not JSON serializable
error in function _wait_for_return after adding a new feather wiki.
error: kex_exchange_identification: Connection closed by remote host
Error processing page. GET /plinth/sys/security/report, exception: Command '['debsecan']' returned non-zero exit status 1.
File "/usr/lib/python3/dist-packages/django/core/handlers/base.py", line 181, in _get_response
can I assume some third party is preventing my box to navigate freely?
It runs on a RaspberryPi3B+
You can find it on vgcfreebox.myrthtech.pt
