I tried installing infinoted in plinth today. When the install finished I was presented the Status message “Service Gobby Server (infinoted) is not running” followed by the “Run Diagnostics” button. Clicking that button I am told that module infinoted test “listening on port 6523” failed for both ipv4 and ipv6
/var/log/syslog has this in it:
infinoted[11615]: Failed to open file '/etc/infinoted/iinfinoted-key.pem': Permission denied
systemd[1]: infinoted.service: Main process exited, code=exited, status=255/n/a
systemd[1]: infinoted.service: Unit entered failed state.
systemd[1]: infinoted.service: Failed with result 'exit-code'.
The ownership on the directory /etc/infinoted is infinoted:infinoted and the permissions are 750. The two pem files in the directory are ownership root:root and permissions 640 or in other words:
$ ls -ld /etc/infinoted
drwxr-x--- 2 infinoted infinoted 4096 May 9 15:06 /etc/infinoted/
$ sudo ls -l /etc/infinoted
-rw-r----- 1 root root 1724 May 9 15:06 infinoted-cert.pem
-rw-r----- 1 root root 3243 May 9 15:06 infinoted-key.pem
Does anyone recognize this problem? Can anyone help me diagnose?
- Debian version: 9.9 stretch
- FreedomBox version: plinth version 0.13.1
- Hardware: Sheevaplug
- How did you install FreedomBox?: I followed the instructions for Sheevaplugs on cyrius.com to install debian 9 to an SD card, then ‘apt install freedombox-setup’
