[SOLVED] PHP2Shell impact on freedombox
From what I read, this seems to affect at least nextcloud and wordpress. Is that correct? I don’t know whether other freedombox apps are impacted.
I guess we don’t have corrections for this yet, so we may prefer to either render a freedombox using vulnerable services not accessible from internet at all, or disable those app.
Do I get it right?
Fixes for the recently discovered security vulnerabilities in PHP (CVE-2026-109618, CVE-2026-109619) have been addressed in Debian’s trixie-security. FreedomBox’s PHP is Debian’s PHP. All users should automatically receive these security updates tonight unless they have disabled automatic software updates. There is no action needed. Please let us know if you this does not happen.
I understand that nextcloud is something from a container, not from Debian. Is that already updated too?
The security updates for the Nextcloud container come from the Nextcloud community. This container seems to have been updated to contain the required version of PHP. You can verify this by running:
# podman exec -it nextcloud-freedombox php --version
PHP 8.5.12 (cli) (built: Oct 21 2026 15:49:51) (NTS)
Copyright (c) The PHP Group
Built by https://github.com/docker-library/php
Zend Engine v4.5.12, Copyright (c) Zend Technologies
    with Zend OPcache v8.5.12, Copyright (c), by Zend Technologies
I have
$sudo podman exec -it nextcloud-freedombox php --version
PHP 8.5.11 (cli) (built: Oct  6 2026 01:23:17) (NTS)
Zend Engine v4.5.11, Copyright (c) Zend Technologies
    with Zend OPcache v8.5.11, Copyright (c), by Zend Technologies
I ran updates manually just before checking. Is there a different way to force an update for this container?
Try re-running setup on Nextcloud app in FreedomBox UI.
Thanks, it is updated now, same version like you showed before.
