I just set up my new FBx based on the Raspberry 4B. It shows a set-up as: Cloud - extern - FBx - intern (Freedombox wlan0) - computer.
a) I do not understand this drawing, thinking about it. My Freedombox is connected to the router (Fritzbox) via Ethernet cable and my computer via WLAN to the Fritzbox. No device is connected directly to the FBx (except the router).
Privoxy says wlan0 is connected as intern. wlan0 of FBx is not used, as it is not configured to connect to my Fritzbox. So I tried to de-activate it and activate “Wired Connection 1”, Ethernet, instead. But now Privoxy says, no connection is available as intern and indeed “networks” does not show it.
b) Does this part “intern” have any importance in the connection.
c) Which would be the correct setting for Privoxy?
There is also “Freedombox WAN, Ethernet” connection visible and of course lo.
On my old box (LIME) it shows “Freedombox WAN, eth0” as “intern” and it is functional (still running on old-stable). There are no other connections available on that device. Thinking about it, I had to delete some connection ages ago in some configuration file to make it work.
When activating WAN on my new box, it is placed as external, not internal as on my old box.
I’ve not had my first cup of coffee yet but I’ll give it a go.
First, internal is supposed to be the connection “internal” to your network. This is not physically feasible with a single-LAN port device like a Pi (barring getting some USB dongle) as you would your average router (which would have one WAN port and a number of LAN ports; the former is external and the later internal).
In the absence of two ports to rig this way, then you’d only have an internal since there is some other device sitting between the FB and the internet performing router, firewall, and other security functions. This device will need port pass through for any services you want available outside your local network.
Thus, you see in the drawing there is no external network interface assignment under external (see my screen cap below)
I’m still on Debian 11 (dodging the Bookworm upgrade for the moment) so I only have Wired Connections. But I got half a cup of coffee in me so I’m seeing a bit clearer.
1- What does the self-diagnostics say in Privoxy?
2- Is its check box in firewall on?
3- What does eth0 connection page show? What is it set as?
I turned on “wired connection 1”, which turns off “WAN” and no connection is shown under “external”. So same as in the manual except that I have wlan0 as “internal”.
eth0 now says “Firewall zone external”. There is a BIG warning that this is a primary connection and making bad changes is not a good idea.
Should I try setting it to internal?
First, let me ask if you have any unbacked up data in case we wreck it.
If you don’t or (this being a fresh install) you have no data, then let’s try setting eth0 to internal, as this should be the only type of connection you have.
Mmmh, this morning the old network configuration was set again:
eth0: deactivated
wlan0: set to intern
No updates were installed over night. Interestingly also the tickmark at “upgrade to next stable” was set, which I had removed. Something reverted these settings to default, I will keep an eye on it.
So I activated again eth0 which was still set to intern.
The changes are stable now and Privoxy is working. I cannot reproduce why the network was reset before.
Now that you mention, I recall that this was what I did ages ago, I just did not write it down in my own notes. Afaik, The intention of the FBx-project is to offer a system that works out of the box, so that anyone can participate in a decentralized internet. So the network connection must be properly set during set-up. This definitely requires some work.
Yeah, it’s in the doco and if you pay attention very carefully during installation you’ll see something fly by telling you that you may need to do this. I’m sure there is a reason why it’s not done during install - maybe because if you are installing on debian from apt you are probably not the target user - and you’ll probably figure it out eventually if you are a command line install customer.
When you define a network interface in /etc/network/interfaces that’s a static setup which NetworkManager will ignore. When you comment these then NetworkManager can take control of those devices. If /etc/network/interfaces were to be replaced or modified without you being aware that would trigger that change you describe. You’re on the right side of it now, and I expect that it won’t happen frequently.
