The letsencrypt certificate expired and didn’t automatically renew. Deletinng (moving) the directory under /etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory didn’t help. Obtaining a new certificate didn’t work.
Failed to obtain certificate for domain xxxx: Saving debug log to /var/log/letsencrypt/letsencrypt.log Plugins selected: Authenticator webroot, Installer None Obtaining a new certificate Performing the following challenges: http-01 challenge for ubuntudigilab.freedombox.rocks Using the webroot path /var/www/html for all unmatched domains. Waiting for verification… Cleaning up challenges Failed authorization procedure. xxxx (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://xxxx/.well-known/acme-challenge/9C9nObga-MR_xxxx: Error getting validation data
The freedombox is plugged into the router.
The letsencrypt certificate has worked until it expired.
Running Debian GNU/Linux 10 (buster) and FreedomBox version 20.11. FreedomBox is up to date.
I looks like your domain is not reachable from the larger Internet. LE certificate must have been reobtained about a month before it got expired.
Verify that the Dynamic DNS IP address pointing to your FreedomBox is correct. Check your IP with curl ipinfo.io on the FreedomBox. Check domain IP with dig <yourdomain>.
If this is the cause, try providing the IP detection URL in the dynamic DNS settings.
Check that your website is reachable from outside say using an alternate network such 4G phone network.
