Matrix Synapse application page > Configure > “The application needs to be updated! Update now?” tries to download and install
matrix-synapse, matrix-synapse-ldap3
but gives > Error during installation E: Unable to correct problems, you have held broken packages.
$ apt list --upgradable -a
Listing… Done
matrix-synapse/buster-backports 1.5.1-1~bpo10+1 all [upgradable from: 0.99.2-6]
matrix-synapse/stable,now 0.99.2-6 all [installed,upgradable to: 1.5.1-1~bpo10+1]
- Login to FreedomBox.
- Go to Matrix Synapse application page.
- Click on the Configure button.
- “The application needs to be updated! Update now?”
- Click on ‘Submit data’ button.
I expected matrix-synapse and matrix-synapse-ldap3 to be upgraded.
I get an error with the following message:
Listing… Done
- FreedomBox version: 19.21 on Raspbian GNU/Linux 10 (buster)
- Hardware: Raspberry Pi 4 Model B
- How did you install FreedomBox?: Raspbian with ‘apt install freedombox’ and manual upgrade via cockpit then upgrade via FreedomBox UI
