Good morning.
I click to install OpenVPN: installation doesn’t go beyong the initial “installing openvpn, easy-rsa”. It yields the following error: “Error installing application: Error during installation E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution)”.
I don’t even know how to open a terminal in FreedomBox. -
I click to install SearX: installation doesn’t go beyond the initial installing searx, uwsgi, uwsgi-plugin-python3. Yields the same error as problem “1”.
Home Screen warns I have 109.3 MiB free space left. I don’t think this is a problem, but feel free to enlighten me how to expand my space.
I can provide the Diagnostics report if needed.
Running VirtualBox 64-bit img: Debian GNU/Linux 10 - FreedomBox version 19.19, on a VirtualBox within my Intel NUC, which is running Windows 10 Pro. I connect to my Intel NUC through TeamViewer.
Successfully installed MediaWiki, MLDonkey, Tor, and Sharing.
MediaWiki and Tor are running just fine. I haven’t used MLD or Sharing.
I’m a non-technical Windows user who knows how to “sudo apt-update” in Linux, and that’s about it.
I connect to my FreedomBox through Tor.
