[SOLVED] Ejabberd MAM Not Working
Hi,
After the last updates to ejabberd, upload and bosh seem configured but mam stopped working. I can message individually from each of my clients but, these messages arent syncing in all of them (didn’t have this problem before).
I believe it may have to do with the order of mods in the ejabberd.yml file, though not sure
  • FreedomBox version: FreedomBox version 23.4
  • Hardware: Raspberry Pi4
  • How did you install FreedomBox?: FBX on top of Pi image of Debian
Any help on this appreciated.
I believe I found a solution to this.
set
mod_mam:
default: always
started working again.
It seems like each client should be able to change the value to be something other than the default:
Note that a client can change its policy via protocol commands.
https://docs.ejabberd.im/admin/configuration/modules/#mod-mam
Thanks @Ged
I have just edited ejabberd.yml and changed to: default: always
And all the clients now synchronize with their chat.
Excellent tweak.
Regards: peter
Not sure but this may also be in the XEP. Nevertheless, in neither Conversations nor Dino have I come across a policy change option for this. I’m guessing it might be better if default value is set to always.
Hello @Ged
Like yourself I can not see any option in Conversations and Dino to set the mod_mam option.
“if default value is set to always.”
From me its - Yes
     Regards: peter
The issue is back. I’ve been searching for an explanation online but cant seem to find one.
Not sure if this is an ejabberd bug or something with freedombox.
P.S. I’ve got my configuration adjusted to use ejabberd TURN/STUN servers so it may look different than your typical FBX configuration. Also, I have no need for BOSH so using a custom UPLOAD folder under /var/www
Sharing my configuration file below:
###              ejabberd configuration file
### The parameters used in this configuration file are explained at
###       https://docs.ejabberd.im/admin/configuration
### The configuration file is written in YAML.
### *******           !!! WARNING !!!               *******
### *******     YAML IS INDENTATION SENSITIVE       *******
### ******* MAKE SURE YOU INDENT SECTIONS CORRECTLY *******
### Refer to http://en.wikipedia.org/wiki/YAML for the brief description.
# loglevel: Verbosity of log files generated by ejabberd
loglevel: info
# rotation: Disable ejabberd's internal log rotation, as the Debian package
# uses logrotate(8).
log_rotate_count: 0
# hosts: Domains served by ejabberd.
# You can define one or several, for example:
# hosts:
#   - "example.net"
#   - "example.com"
#   - "example.org"
hosts:
- my_domain.com
certfiles:
- "/etc/ejabberd/ejabberd.pem"
#  - /etc/letsencrypt/live/localhost/fullchain.pem
#  - /etc/letsencrypt/live/localhost/privkey.pem
# TLS configuration
define_macro:
  'TLS_CIPHERS': "HIGH:!aNULL:!eNULL:!3DES:@STRENGTH"
  'TLS_OPTIONS':
  - "no_sslv3"
  - "no_tlsv1"
  - "no_tlsv1_1"
  - "cipher_server_preference"
  - "no_compression"
    # 'DH_FILE': "/path/to/dhparams.pem"
    # generated with: openssl dhparam -out dhparams.pem 2048
c2s_ciphers: 'TLS_CIPHERS'
s2s_ciphers: 'TLS_CIPHERS'
c2s_protocol_options: 'TLS_OPTIONS'
s2s_protocol_options: 'TLS_OPTIONS'
# c2s_dhfile: 'DH_FILE'
# s2s_dhfile: 'DH_FILE'
listen:
- port: 5222
  ip: "::"
  module: ejabberd_c2s
  max_stanza_size: 262144
  shaper: c2s_shaper
  access: c2s
  starttls_required: true
- port: 5223
  ip: "::"
  shaper: c2s_shaper
  access: c2s
  tls: false
- port: 5269
  ip: "::"
  module: ejabberd_s2s_in
  max_stanza_size: 524288
- port: 5443
  ip: "::"
  module: ejabberd_http
  tls: true
  request_handlers:
    /api: mod_http_api
    /bosh: mod_bosh
      ## /captcha: ejabberd_captcha
    /upload: mod_http_upload
    /ws: ejabberd_http_ws
- port: 5280
  ip: "::"
  tls: false
  request_handlers:
    /admin: ejabberd_web_admin
    /.well-known/acme-challenge: ejabberd_acme
- port: 1883
  ip: "::"
  module: mod_mqtt
  backlog: 1000
# https:uwot.eu / www.process-one.net/blog
- port: 3478
  transport: udp
  module: ejabberd_stun
  use_turn: true
  turn_min_port: 49152
  turn_max_port: 50175
  turn_ip: my_static_ip
  auth_type: user
- port: 5349
  transport: tcp
  use_turn: true
  tls: true
  ip: "::"
## Disabling digest-md5 SASL authentication. digest-md5 requires plain-text
## password storage (see auth_password_format option).
disable_sasl_mechanisms:
- "digest-md5"
- "X-OAUTH2"
s2s_use_starttls: required
## Store the plain passwords or hashed for SCRAM:
auth_password_format: scram
## Full path to a script that generates the image.
## captcha_cmd: "/usr/share/ejabberd/captcha.sh"
acl:
  admin:
    user:
  local:
    user_regexp: ""
  loopback:
    ip:
    - 127.0.0.0/8
    - ::1/128
access_rules:
  local:
    allow: local
  c2s:
    deny: blocked
    allow: all
  announce:
    allow: admin
  configure:
    allow: admin
  muc_create:
    allow: local
  pubsub_createnode:
    allow: local
  trusted_network:
    allow: loopback
api_permissions:
  "console commands":
    - ejabberd_ctl
    who: all
    what: "*"
  "admin access":
    who:
      access:
        allow:
        - acl: loopback
        - acl: admin
      oauth:
        scope: "ejabberd:admin"
        access:
          allow:
          - acl: loopback
          - acl: admin
    what:
    - "!stop"
    - "!start"
  "public commands":
    who:
      ip: 127.0.0.1/8
    what:
    - status
    - connected_users_number
shaper:
  normal:
    rate: 3000
    burst_size: 20000
  fast: 200000
shaper_rules:
  max_user_sessions: 10
  max_user_offline_messages:
    5000: admin
    100: all
  c2s_shaper:
    none: admin
    normal: all
  s2s_shaper: fast
modules:
  mod_adhoc: {}
  mod_admin_extra: {}
  mod_announce:
    access: announce
  mod_avatar: {}
  mod_blocking: {}
  mod_bosh: {}
  mod_caps: {}
  mod_carboncopy: {}
  mod_client_state: {}
  mod_configure: {}
  ## mod_delegation: {}   # for xep0356
  mod_disco: {}
  mod_fail2ban: {}
  mod_http_api: {}
  mod_http_upload:
    put_url: https://@HOST@:5443/upload
    docroot: /var/www/upload
    custom_headers:
      "Access-Control-Allow-Origin": "https://@HOST@"
      "Access-Control-Allow-Methods": "GET,HEAD,PUT,OPTIONS"
      "Access-Control-Allow-Headers": "Content-Type"
  mod_last: {}
  ## mod_mam:
  ##   ## Mnesia is limited to 2GB, better to use an SQL backend
  ##   ## For small servers SQLite is a good fit and is very easy
  ##   ## to configure. Uncomment this when you have SQL configured:
  ##   ## db_type: sql
  ##   assume_mam_usage: true
  ##   default: always
  mod_mqtt: {}
  mod_muc:
    access:
    - allow
    access_admin:
    - allow: admin
    access_create: muc_create
    access_persistent: muc_create
    access_mam:
    - allow
    default_room_options:
      mam: true
  mod_muc_admin: {}
  mod_offline:
    access_max_user_messages: max_user_offline_messages
  mod_ping: {}
  mod_pres_counter:
    count: 5
    interval: 60
  mod_privacy: {}
  mod_private: {}
  ## mod_proxy65:
  ##   access: local
  ##   max_connections: 5
  mod_pubsub:
    access_createnode: pubsub_createnode
    plugins:
    - flat
    - pep
    force_node_config:
      "eu.siacs.conversations.axolotl.*":
        access_model: open
      ## Avoid buggy clients to make their bookmarks public
      storage:bookmarks:
        access_model: whitelist
  mod_push: {}
  mod_push_keepalive: {}
  ## mod_register:
  ##   ## Only accept registration requests from the "trusted"
  ##   ## network (see access_rules section above).
  ##   ## Think twice before enabling registration from any
  ##   ## address. See the Jabber SPAM Manifesto for details:
  ##   ## https://github.com/ge0rg/jabber-spam-fighting-manifesto
  ##   ip_access: trusted_network
  mod_roster:
    versioning: true
  mod_s2s_dialback: {}
  mod_shared_roster: {}
  mod_sic: {}
  mod_stream_mgmt:
    resend_on_timeout: if_offline
  mod_stun_disco:
    credentials_lifetime: 1000d
    secret: secret
    services:
    - host: my_domain.com
      port: 3478
      type: stun
      transport: tcp
      port: 3478
      type: stun
      transport: udp
      port: 3478
      type: turn
      transport: tcp
      port: 3478
      type: turn
      transport: udp
  mod_vcard:
    search: false
  mod_vcard_xupdate: {}
  mod_version: {}
  mod_mam:
    db_type: mnesia
    default: always
    request_activates_archiving: false
    assume_mam_usage: false
    cache_size: 1000
    cache_life_time: 3600
auth_method: ldap
ldap_servers:
- "localhost"
ldap_base: "ou=users,dc=thisbox"
### Local Variables:
### mode: yaml
### End:
### vim: set filetype=yaml tabstop=8
s2s_certfile: "/etc/ejabberd/letsencrypt/my_domain.com/ejabberd.pem"
OK. Got it working again : )
So here’s what’s happening for anyone (like me) who has no idea about the internals of the application.
In the FBX setup, ejabberd is configured to use its own database (mnesia) to store mam messages. This database is limited to a size of 2GB (if you need anything more, you need to revert to another sql database - i.e. sqlite or postgresql).
When testing for the culprit, my system log threw me a [error] MAM archives too large, won't store message for me@mydomain.com eroor.
Apperantly, the database on my server had reached its limits and was not storing any more messages. The following command can be used to clear the database:
ejabberdctl delete_old_mam_messages all 0
use with sudo
Explanation:
If you do a ejabberdctl help delete_old_mam_messages the notation will explain to select “chat, groupchat or all.” The “0” at the end is to specify messages “older than days”
So, the command above is trigerred for “all” messages “older than 0” days old.
I may put this as monthly a cronjob under root.
Good luck.
