I am trying to use the samba share from freedombox running on a raspberrypi 2 using an external SSD. In the webinterface i can see that samba is installed and the group share is enabled. The SSD is mounted. When i try to connect via PCManFM to the share i get Failed to mount Windows share: Invalid argument, Dolphin just prompts me for the user credentials over and over. In the samba logs i get:
../../lib/param/loadparm.c:815(lpcfg_map_parameter)
Unknown parameter encountered: "access control"
../../lib/param/loadparm.c:1855(lpcfg_do_global_parameter)
Ignoring unknown parameter "access control"
I already read multiple of the samba related topics here, but nothing really helped.(for example network is there and enabled and file permissions are correct) The location is also accessible via terminal.
- Login to FreedomBox.
- Go to Samba application page.
- Click on the install button.
- Select ‘Enable group share’ option for external SSD.
- Try to connect to share with filemanager.
Samba share gets mounted.
I get an error with the following message:
- FreedomBox version: 23.6
- Hardware: RaspberryPI 2
- How did you install FreedomBox?: downloading RaspberryPI 2 image from freedombox.org
