- I haven’t connected FreedomBox. Just arrived 2023-1-30. Afraid to “strip” the screw - is it a Phillips head screw & turned counter-clockwise to open?
Thank you
Yes, exactly. Just an ordinary screw, go for it.
Thank you for the response. I decided to wait on connecting the battery since that is not necessary to install FreedomBox. But I did try to loosen it with a screwdriver and also with a power drill (low RPM’s) and the screw did not turn counter-clockwise or clockwise. Again, thanks.!!
