I’ve been lurking on the IRC for the past several months and have yet to see 1 person from freedom box respond to a user seeking assistance.
If there can be no representation from FB on IRC, I strongly recommend closing it and just using forums for all levels of support.
IRC exists for some level of real time communication - if that can’t be provided in the slightest bit - I think it should be temporarily closed until we see an uptick in requests.
I didn’t know there was a second. After looking at it , the chat.freednode.net is the one that has zero activity.
I would recommend closing the one that has had zero engagement , and the least amount of support request. I suspect that is chat.freenode.net.
The fact that there are two compounds the point that we should close it (or 1 of them) so as to increase the odds and probably for positive experiences by funneling users (and devs) for real time interaction via irc chat.
I would suggest one “officially” from freedombox.org may gain some oper mode on that old IRC channel, then change Topic to invite visitors to the good one.
It will likely require to have operator privileges in that channel, or to contact a person in the channel who has those privileges, or to ask freenode staff.
