Hi all,
FBX Ver: 25.1 FreedomBox is up to date.
Installation image from FBX website for Raspi 4B
FBX installed on external SSD
In Plinth, Re-run setup for Storage Snapshots returns below error.
Error updating app: '.snapshots subvolume not found in /'
Error running action: snapshot..setup(5): KeyError(".snapshots subvolume not found in /")
Action traceback:
╞ File "/usr/lib/python3/dist-packages/plinth/actions.py", line 398, in _privileged_call
╞ return_values = func(*arguments['args'], **arguments['kwargs'])
╞ File "/usr/lib/python3/dist-packages/plinth/modules/snapshot/privileged.py", line 35, in setup
╞ _add_automount_unit('/')
╞ File "/usr/lib/python3/dist-packages/plinth/modules/snapshot/privileged.py", line 185, in _add_automount_unit
╞ subvolume = _get_subvolume_path(mount_point)
╞ File "/usr/lib/python3/dist-packages/plinth/modules/snapshot/privileged.py", line 165, in _get_subvolume_path
╞ raise KeyError(f'.snapshots subvolume not found in {mount_point}')
lsblk -f output as below
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat FAT16 XXXX-XXXX 100,3M 61% /boot/firmware
└─sda2 btrfs XXXX-XXXX 334,9G 24% /.snapshots
sdb
└─sdb1 ext4 1.0 disk1 XXXX-XXXX 1,1T 33% /media/root/disk1
sdc
└─sdc1 ext4 1.0 disk2 XXXX-XXXX 206,8G 72% /media/root/disk2
sdd
└─sdd1 ext4 1.0 disk3 XXXX-XXXX 563,9G 33% /media/root/disk3
zram0 [SWAP]
df -h output as below
Filesystem Size Used Avail Use% Mounted on
udev 3,8G 0 3,8G 0% /dev
tmpfs 781M 76M 705M 10% /run
/dev/sda2 466G 111G 335G 25% /
tmpfs 3,9G 1,1M 3,9G 1% /dev/shm
tmpfs 5,0M 0 5,0M 0% /run/lock
/dev/sda1 256M 156M 101M 61% /boot/firmware
/dev/sdc1 916G 663G 207G 77% /media/root/disk2
/dev/sda2 466G 111G 335G 25% /.snapshots
/dev/sdd1 916G 306G 564G 36% /media/root/disk3
/dev/sdb1 1,8T 609G 1,2T 35% /media/root/disk1
tmpfs 781M 0 781M 0% /run/user/10000
fstab as below
UUID=XXXX-XXXX / btrfs compress=zstd:1 0 1
UUID=XXXX-XXXX /boot/firmware vfat errors=remount-ro 0 2
UUID=XXXX-XXXX /media/root/disk1 ext4 x-systemd.automount 0 2
UUID=XXXX-XXXX /media/root/disk2 ext4 x-systemd.automount 0 2
UUID=XXXX-XXXX /media/root/disk3 ext4 x-systemd.automaount 0 2
snapper works perfectly with no errors in creating or restoring snapshots.
Would anyone have any thoughts on this error and how to resolve it?
Thanks in advance.
