I downloaded a fresh nightly image for the raspberry 4, model B and verified it. After putting it on an micro-SD Card, inserting it and waiting for 10 minutes, it won’t show up in my Huawei HG659. I can’t find an ip-address either. The raspberry pi is connect through the ethernet port with a CAT 7 ethernet cable. The cable is attached before starting the device. I’m not using any other modem or switch. Both the red light and the network indicator lights are flashing. I’ve tried reaching the raspberry pi through the firefox browser on an Arch Linux install.
Why won’t it show up? What can I do to solve this? Should I open some ports? Any help would be greatly appreciated.
Second Problem Description
I’m facing the same problems with my raspberry pi 3, model B+, with an stable image, except, the network indicator lights won’t flash on this device.
Being able to connect to the device through freedombox(.local) or an IP
Device(s) not reachable or showing up in my router’s firmware interface.
Can you assign a static IP address? FreedomBox uses NetworkManager. Mount the SD card on Arch Linux. Navigate to /mount/point/etc/NetworkManager/system-connections/
You should see a *.nmconnection file for the Pi’s ethernet cable connection. Here is my ipv4 section.
Thank you for replying. No such file is present. As soon as my microHDMi cable arrives today, I will look at the errors on the screen. I have also tried the seperate uefi driver on a micro-sd, yet nothing boots.
So apparently this worked. I got it running on a debian image for raspberry pi, by hooking op a monitor. I didn’t try this method yet.
Now I got it running on a raspbian OS lite image. This doesn’t seem to be a permanent solution however. Is there a way to always allow internal traffic (within the network) but not allowing external incoming traffic?
Edit: I got it fixed by settting a static ip in Arch and adding it to the internal zone of firewalld on freedombox. I did a lot of searching today but I finally did it.
