I setted up my Freedombox on a Raspberry Pi 3 Model B for the second time today.
The initial network configuration was: Freedombox connected to a router, Router is currently unconfigured, I do not know the type of connection my ISP provides. This because I want all services of my Freedombox only over tor.
After the first update I installed first tor and then ejabberd.
Then I created a user called “test” under User and Groups without any permissions (there is no ejabberd permission on that page).
After that I used Gajim to connect to my ejabberd server, with the following parameters:
test@dop1lsmxnz9dkepajgbs8ckemcnslrp1ps9ckdmzlayurbiwur0vbajs.onion
Advanced Settings->Login
Proxy:
I created a proxy called Tor with SOCKS5 127.0.0.1 9050 no proxy authentication.
(I have tor installed on my client that respond on port 9050)
$ sudo ss -tulpn | grep 9050
tcp   LISTEN 0      4096         127.0.0.1:9050       0.0.0.0:*    users:((“tor”,pid=1046,fd=6))
Hostname: dop1lsmxnz9dkepajgbs8ckemcnslrp1ps9ckdmzlayurbiwur0vbajs.onion
Port: 5222
Type: START TLS
But when I press Login I have a error of connection failed. Can’t reach the server.
I also tryed with Conversations on my Android but same. It seems the server is not reachable.
I am not so expert about tor so I need a hand.
Thank you.
