Firstly, thanks to everyone behind this project. It is a very convenient way of “self-hosting” many services necessary for daily digital life while preserving privacy.
I was running my Freedombox instance for many years until I managed to damage it to the point of no return Fortunatelly, I had backups (via custom Duplicity script). Unfortunately, my approach to restoring them was quite crude. I reinstalled the system (clean installation of Freedombox) then selectively copied files from the backup into the fresh system - mostly from /etc and /home folders. This lead to all sorts of issues with permissions and inconsistencies between the installed packages and the file system, but I brute-forced my way to more-or-less working system.
One issue remained, however: Plinth (and therefore the rest of the Freedombox) fails to auto-start after reboot. Systemctl status page prints: (code=exited, status=2)
(complete output below).
Manually starting plinth as root, using either:
plinth
or/usr/bin/plinth > /var/log/plinth.log 2> /var/log/plinth-error.log
orsudo -H -u plinth bash -c 'plinth'
works as expected and produces no errors (just one warning: WARNING django.security.csrf Forbidden (CSRF token missing or incorrect.): /plinth/accounts/sso/login/
- Reboot the system
- Try to open the web interface
Web interface available.
Web interface not available. After ssh-ing in and checking the status of the service, error below.
- FreedomBox version: 23.6.2
- Hardware: Physical server, AMD Ryzen 5 5600G
- How did you install FreedomBox?: ‘apt install freedombox’ and then above-described backup restoration process.
Systemctl status output:
● plinth.service - FreedomBox Service (Plinth)
Loaded: loaded (/etc/systemd/system/plinth.service; enabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2023-09-12 10:07:46 CEST; 684ms ago
Docs: man:plinth(1)
Process: 129421 ExecStart=/usr/bin/plinth > /var/log/plinth.log 2> /var/log/plinth-error.log (code=exited, status=2)
Main PID: 129421 (code=exited, status=2)
CPU: 399ms
/etc/systemd/system/plinth.service has following contents:
# SPDX-License-Identifier: AGPL-3.0-or-later
[Unit]
Description=FreedomBox Service (Plinth)
Documentation=man:plinth(1)
After=network.target
StartLimitIntervalSec=0
[Service]
Restart=on-failure
RestartSec=5
ExecReload=/bin/kill -HUP $MAINPID
User=plinth
Group=plinth
StandardOutput=null
StandardError=null
[Install]
WantedBy=multi-user.target
