I purchased the FreedomBox Pioneer in May 2019. I have been intermittently using it since. Really haven’t had time to devote to it.
Yesterday, I commented out one line in /etc/apache2/conf-available/freedombox.conf file.
I had this line commented out before a previous update. The update put the file back. So I thought changing it back again wouldn’t hurt.
I restarted apache to see if the change would apply. It didn’t. So I used the “systemctl reboot” to restart the box.
The box did not come back up.
Plugging in the HDMI cable, I see it gets to “Starting Kernel” then there is a blank screen with a flashing cursor in the top-right corner of the screen.
There is a green light on the board. A red light next to the power cable. And the network light is flashing.
Otherwise, there is no other feedback.
Please help.
Thanks
I took a picture of the boot screen and transcribed the results in case it helps:
U-Boot 2019.01 (Apr 16 2019 - 19:05:34 -400) Allwinner Technology
CPU: Allwinner A20 (SUN71)
Model: Olimex A20-OLinuXino-LIMEZ
I2C: ready
DRAM: 1 GiB
MMC: SUNXI SD/MMC: 0
Loading Environment from FAT… Unable to use mmc 0:1… HDMI connected: Setting up 1920x1000 hdmi console (overscan 0x0)
In: serial
Out: vga
Err: vga
Allwinner mUSB OTG (Peripheral)
SCSI: SATA link 0 timeout.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net: eth0:ethernet@1c50000
Warning: usb_ether using MAC address from ROM
, eth1: usb_ether
starting USB…
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: USB EHCI 1.00
USB3: USB OHCI 1.0
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 2 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
Found U-Boot script /boot.scr
2627 bytes read in 8 ms (320.3 (KiB/s)
Executing script at '43100000
Mainline u-boot / new-style environment detected.
4391424 bytes read in 13 ms (15.9 MiB/s)
27170 bytes read in 13 ms (2 MiB/S)
Booting Debian 4.19.06-armmp-lpae from mmc 0:1
Flattened Device Tree blob at 43000000
Booting using the fdt blob at Ox43000000
EHCI failed to shut down host controller.
Loading Ramdisk to 48b6a000, end 49fffb0b … OK
Loading Device Tree to 48b6a000, end 48b69a21 … OK
Starting kernel …
I tried to plug in an USB keyboard to stop the boot process. But that didn’t work either.
I have this same issue. Did you figure out a good solution and get back up and running? If so, what did you do?
Thank you for your assistance!
