I am an inexperienced linux user. I tried to partition a brand-new external USB HDD via ssh, and could not.
dmesg log (more complete log below):
[20260.159142] sd 1:0:0:0: Device offlined - not ready after error recovery
[20260.159306] sd 1:0:0:0: rejecting I/O to offline device
[20260.165379] sd 1:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
I wonder if the A20-OLinuXino-LIME2 board can’t supply enough power to power the router and spin the HDD?
I believe this is a different problem than USB flash drive not appear, Mount encrypted ext4 disk, and Adding external USB HDD to a Freedombox.
- I’m talking to my brand-new Pioneer Edition Freedombox through a brand-new GL-MT300N-V2 wireless router. The LIME2 board is powered via the PWR jack with 5V DC, and supplies power to the router via one of its two USB hosts.
- I connected a brand-new Seagate Backup Plus Slim Portable 1 TB HDD to the LIME2 board’s other USB host, with intention to partition it, install a filesystem, and use it as network storage. The LIME2 is the HDD’s only source of power. The HDD’s light comes on.
- I expected to see the HDD in plinth > system > storage.
- I expected to discover the hdd with
udevadm info --query=all --name=/dev/sda - I expected to discover the hdd with
fdisk -l - I expected to discover the hdd with
lsblk -a - I expected to be able to begin to partition the hdd with
parted --align=opt /dev/sda
Failure. plinth > system > storage displays /dev/mmcblk0p1 and /dev/mmcblk0p2, but not the HDD.
Success.
udevadm info --query=all --name=/dev/sda:/dev/disk/by-path/platform-1c1c000.usb-usb-0:1:1.0-scsi-0:0:0:0 /dev/disk/by-id/usb-Seagate_BUP_Slim_00000000NAB56DCJ-0:0 -
Failure.
fdisk -l:Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x1af3e6b0Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 * 2048 264192 262145 128M 83 Linux
/dev/mmcblk0p2 266240 62333951 62067712 29.6G 83 Linux -
Success?
lsblk -a:NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 1 disk
mmcblk0 179:0 0 29.7G 0 disk
|-mmcblk0p1 179:1 0 128M 0 part /boot
`-mmcblk0p2 179:2 0 29.6G 0 part / -
Failure.
sudo parted --align=opt /dev/sda:error: Error opening /dev/sda: No such device or address.
output of dmesg after attaching HDD
[20007.293237] usb 2-1: new high-speed USB device number 4 using ehci-platform
[20007.498831] usb 2-1: New USB device found, idVendor=0bc2, idProduct=ac30, bcdDevice=17.07
[20007.498849] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[20007.498856] usb 2-1: Product: BUP Slim
[20007.498863] usb 2-1: Manufacturer: Seagate
[20007.498870] usb 2-1: SerialNumber: 00000000NAB56DCJ
[20007.511731] scsi host1: uas
[20007.516599] scsi 1:0:0:0: Direct-Access Seagate BUP Slim 1707 PQ: 0 ANSI: 6
[20007.522496] sd 1:0:0:0: Attached scsi generic sg0 type 0
[20055.658092] sd 1:0:0:0: [sda] Spinning up disk...
[20076.720266] ...not responding...
[20249.337920] sd 1:0:0:0: tag#28 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[20249.337952] sd 1:0:0:0: tag#28 CDB: Read capacity(16) 9e 10 00 00 00 00 00 00 00 00 00 00 00 20 00 00
[20249.353924] scsi host1: uas_eh_device_reset_handler start
[20249.481992] usb 2-1: reset high-speed USB device number 4 using ehci-platform
[20249.691236] scsi host1: uas_eh_device_reset_handler success
[20259.821775] sd 1:0:0:0: tag#28 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[20259.821805] sd 1:0:0:0: tag#28 CDB: Test Unit Ready 00 00 00 00 00 00
[20259.821819] scsi host1: uas_eh_device_reset_handler start
[20259.949856] usb 2-1: reset high-speed USB device number 4 using ehci-platform
[20260.159108] scsi host1: uas_eh_device_reset_handler success
[20260.165394] sd 1:0:0:0: [sda] Sense not available.
[20260.165454] sd 1:0:0:0: rejecting I/O to offline device
[20260.181958] sd 1:0:0:0: rejecting I/O to offline device
[20260.187346] sd 1:0:0:0: rejecting I/O to offline device
[20260.199914] sd 1:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[20260.199934] sd 1:0:0:0: [sda] Sense not available.
[20260.200011] sd 1:0:0:0: rejecting I/O to offline device
[20260.212772] sd 1:0:0:0: rejecting I/O to offline device
[20260.218178] sd 1:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[20260.218189] sd 1:0:0:0: [sda] 0-byte physical blocks
[20260.218244] sd 1:0:0:0: rejecting I/O to offline device
[20260.231245] sd 1:0:0:0: [sda] Write Protect is on
[20260.231266] sd 1:0:0:0: [sda] Mode Sense: 54 19 b7 c9
[20260.231345] sd 1:0:0:0: rejecting I/O to offline device
[20260.236912] sd 1:0:0:0: rejecting I/O to offline device
[20260.242694] sd 1:0:0:0: [sda] No Caching mode page found
[20260.248117] sd 1:0:0:0: [sda] Assuming drive cache: write through
[20260.254335] sd 1:0:0:0: rejecting I/O to offline device
[20260.259661] sd 1:0:0:0: rejecting I/O to offline device
[20260.265052] sd 1:0:0:0: rejecting I/O to offline device
[20260.275134] sd 1:0:0:0: [sda] Attached SCSI disk
- FreedomBox version: 20.2
- Hardware: Olimex A20-OLinuXino-LIME2
- How did you install FreedomBox?: Bought pre-installed hardware (pioneer edition)
- uname -a: Linux freedombox 4.19.0-8-armmp-lpae #1 SMP Debian 4.19.98-1 (2020-01-26) armv7l GNU/Linux
