- Whether your FreedomBox is plugged into a router at home or not (if not, please specify how it is connected to the internet)
- The month and year you bought your kit (feel free to omit if you want to preserve some privacy, but this could be helpful information)
- The version of FreedomBox your are running (available by clicking on the “?” in the top menu --> “About”)
Hi - I bought my kit in Sept. 2019. I am using version 20.8. My setup is typical (i.e. FB is plugged into home router).
I am using the openvpn server and connecting to it from both my laptop and desktop using the same username. While the setup works fine individually, I am unable to establish simultaneous connections from both computers. Is this normal?
Is there a solution, other than creating multiple users on the fb?
Thanks!!!
