Nextcloud video player, ffmpeg path issue?
I have Freedombox running on a pc with 12 g ram and it runs nicely. I installed Debian directly on it first and then freedombox. I use nextcloud with the memories photo app on it and other apps as well.
I know that Nextcloud is supposed to be supported by the nextcloud folks and I am looking into the question I have with them but maybe someone here knows the answer.
The admin section in nextcloud asks me for the path to find ffmpeg and ffprobe. It says it can’t find them. They are both installed but nothing I put in the path setting in the admin panel seems to work to allow the system to find them. The result is that there are no thumbnails displayed for video files and they can’t be played.
Status
You are running Debian GNU/Linux 13 (trixie) and FreedomBox version 26.8. FreedomBox is up to date.
I tried
/usr/bin/ffmpeg
/usr/bin/ffprobe
as well but that made no difference.
