Nextcloud: Collabora requesting from the wrong URL
Really excited about the addition of Nextcloud to FreedomBox. Thank you! I’ve been trying it out today, and I noticed that the log was telling me about an error with Collabora Office. It’s requesting a URL that doesn’t exist it looks like:
ClientException Client error: `GET https://aangat.lahat.computer/nextcloud/nextcloud/custom_apps/richdocumentscode/proxy.php?req=/hosting/capabilities` resulted in a `404 Not Found` response: File not found.
Failed to fetch the Collabora capabilities endpoint: Client error: `GET https://aangat.lahat.computer/nextcloud/nextcloud/custom_apps/richdocumentscode/proxy.php?req=/hosting/capabilities` resulted in a `404 Not Found` response: File not found.
If you notice, it’s trying to get nextcloud/nextcloud. Is there a place in the config where I can fix this?
Thanks again!
  • FreedomBox version: Debian GNU/Linux 12 (bookworm) and FreedomBox version 24.11.
  • Hardware: Vultr VPS
  • How did you install FreedomBox?: apt install
Nextcloud, apart from the core product, provides additional integrations with Nextcloud meeting product, Collabora document editing, etc. In FreedomBox, we have so far only worked on the core product. We have not setup Collabora office and have not integrated it with Nextcloud yet. This is likely the reason you are seeing this error.
If you really wish to use Collabora office integration, you will need to setup and configure it yourself. You might find the necessary information in the Nextcloud administrator manual. If you do this, let us know, and we could use that knowledge to implement in FreedomBox.
Since Collabora CODE is finally available as app, I was able to install and activate it via a nextcloud admin account.
I had to search a little to find all pieces, but it is quick and easy if you know how:
should result in a status message at top of page like:
Collabora Online server is reachable.
Then everything should be fine, create new should list presentation etc.
There are user specific settings for office, too (e.g. for Zotero integration).
Today a part of my settings page does not load (404):
example.com/browser/dist/admin/adminIntegratorSettings.html
