Newbie- I cannot exit Apache, pls help!
Hello everybody. Sorry for the long post, but…
I just got my pioneer freedombox up and running behind my TPLink A7 router. At first, everything was fine, I could access the main page with freedombox.local, etc. I set up the free DDNS with GNUDip, and could access the main page fine.
Then I started Apache.
Now when I log on, either by freedombox.local or by myname.fbx.one, it takes me to the default Apache 2 Debian Default page, and no matter what Ive tried I cant get back to the Freedombox main menu.
I even tried using ssh to log in and stopped the Apache server, but when I do that, I cannot access Freedombox at all.
I did an update when i first started freedom box, so all the software is current.
If anybody can help, it would be greatly appreciated, thanks.
Hello @TDosh
From your local network you can use the url below to get to your login page of your freedombox:
https://freedombox.local/plinth/
On the " General Configuration" page of your freedombox you can change the: " Webserver Home Page "
https://freedombox.local/plinth/sys/config/
Regards: peter
wow, thanks so much Peterc, worked like a charm!
Cheers, Tom
