My FreedomBox no longer starts up after a system update
Hi,
My FreedomBox no longer starts up after a system update.
I can no longer see the BOX on my network either.
I don’t have SSH access either.
I need help
moji
Hello!
To give you any suggestion, some details are needed like:
  • on which hardware does it run?
  • how did you install freedombox?
  • how is your freedombox connected to your local network (ethernet, wireless)?
  • how do you normally access your freedombox?
  • did you use the option to get frequent udates?
  • did the problem occur after a manual or automatic update?
Thank you for your reply.
I’ve now restarted the device and the SD card.
I couldn’t wait any longer, sorry.
Regards,
moji
Does it work now?
It sometimes (not often) happens that my freedombox is completely unresponsive. Powering it off and is a way to restore it. For my freedombox running on an SD card, I normally put the SD card in an SD card reader on my PC to check the filesystem, and then I put it back to the Freedombox.
Having backups is a good idea in case something really wrong (like, damaged SD card) happened.
I don’t have enough experience to know what to look out for.
Where can I learn this?
Thank you,
Moji
