MiniDLNA media location - Drop down menu option
Hello all and thanks for Freedombox !!
Suggestion
Would it be possible to have a Drop down menu option for the media location for MiniDLNA config page, to set location ?
A Drop down menu like you have done for:
Transmission and Deluge config pages.
It would make it easy to allow MiniDLNA to share media from:
Transmission or Deluge download directory and Samba open_share directory.
Reason for a menu is to make it more understandable to a user to pick a location for MiniDLNA work from.
Locations options that would be helpful:
Default location.
/var/lib/minidlna
Extras locations.
/var/lib/transmission-daemon/downloads
/var/lib/deluged/Downloads
/var/lib/freedombox/shares/open_share
Regards: peterc
  • FreedomBox version:
Debian GNU/Linux bullseye/sid and FreedomBox version 21.2
  • Hardware:
Laptop: LENOVO 0769ECG
  • How did you install FreedomBox ?:
apt install freedombox on Debian testing ’ bullseye ’
Since I didn’t see the issue on Salsa, I opened one here: minidlna: Add storage location dropdown (#2084) · Issues · FreedomBox / FreedomBox · GitLab
Hello @jvalleroy
It would be handy to have the samba group add to the menu option of miniDLNA.
/var/lib/freedombox/shares/group_share
Regards: peter
