This error occurred with each attempt to auto renew. I was able to renew manually after the certificate expired
2020-08-28 03:28:31,472:WARNING:certbot.renewal:Attempting to renew cert (redacted.domain.name) from /etc/letsencrypt/renewal/redacted.domain.name.conf produced an unexpected error: Missing command line flag or config entry for this setting:
Input the webroot for redacted.domain.name:. Skipping.
2020-08-28 03:28:31,496:DEBUG:certbot.renewal:Traceback was:
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 452, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1193, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 116, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 310, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
File "/usr/lib/python3/dist-packages/certbot/client.py", line 353, in obtain_certificate
orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names)
File "/usr/lib/python3/dist-packages/certbot/client.py", line 389, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 75, in handle_authorizations
resp = self._solve_challenges(aauthzrs)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 139, in _solve_challenges
resp = self.auth.perform(all_achalls)
File "/usr/lib/python3/dist-packages/certbot/plugins/webroot.py", line 81, in perform
self._set_webroots(achalls)
File "/usr/lib/python3/dist-packages/certbot/plugins/webroot.py", line 99, in _set_webroots
known_webroots)
File "/usr/lib/python3/dist-packages/certbot/plugins/webroot.py", line 120, in _prompt_for_webroot
webroot = self._prompt_for_new_webroot(domain, True)
File "/usr/lib/python3/dist-packages/certbot/plugins/webroot.py", line 144, in _prompt_for_new_webroot
force_interactive=True)
File "/usr/lib/python3/dist-packages/certbot/display/ops.py", line 372, in validated_directory
validator, *args, **kwargs)
File "/usr/lib/python3/dist-packages/certbot/display/ops.py", line 329, in _get_validated
code, raw = method(message, default=default, **kwargs)
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 583, in directory_select
return self.input(message, default, cli_flag)
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 524, in input
self._interaction_fail(message, cli_flag)
File "/usr/lib/python3/dist-packages/certbot/display/util.py", line 469, in _interaction_fail
raise errors.MissingCommandlineFlag(msg)
certbot.errors.MissingCommandlineFlag: Missing command line flag or config entry for this setting:
2
3 / 3
Letsencrypt failed to autorenew: Missing commandline flag
