This a follow up on a previous topic, Setting up FB as router troubles , but a different focus. Since Sunil mentioned that having the router behind the nat should not be a cause for problems, and tinkering was taking down the whole household, I put FB behind the router. I changed to an older router, thinking that it could be the problem, but still same issues. Here is a screenshot of the router that seems to tell me that my ISP doesn’t give me an external IP
Diagnostics indicates failure for Mumble
and full failure for LetsEncrypt and Networks.
I must add that I installed today COTURN, but has not helped (yet).
Addtionally, curl -4 http://myip.datasystems24.de provides an IP, same one as dig myname.freedombox.rocks, but ping myname.freedombox.rocks has 100% failure, I assume router does not respond.
Thanks for the help and time.
The question would be if your Internet Service Provider (ISP) gives you a local address and then later translates it to a public internet address, maybe that is the reasons you are having 10.0.0.11 as an IP address.
Just to confirm, your router R6250 is directly connected to the internet? You have no other router in between your internet and yourself?
Yes, I think that this is the only explanation. Because I have tried these two configurations:
(ISP-provided-end) <–> Router <–> FB
and
(ISP-provided-end) <–> FB <–> Router <–> other devices
and in both cases letsencrypt fails.
And I have tried DMZ, and port forwarding in the first configuration.
I changed the router back to Linksys Smart Wifi AC1750, run diagnostics again, and this time only networks and letsencrypt fail, both completely. All others passed with green.
curl -4 and dig give results as expected; ping has 100% loss.
This router is DMZ-ed and forwards besides required ports for COTURN, since DMZ didn’t seem to do the work for it.
Configuration: (ISP-end) <–> Router <–> FB, other devices
