Lets Encrypt Failing
I received an alert that there were to diagnostics that failed.
I am also unable to connect to the freedombox using the URL myhost.freedombox.rocks.
System diagnostics for Let’s Encrypt show two failures:
Access URL https://myhost.freedombox.rocks
Let’s Encrypt Fails Diagnostics. Attempts to repair the app results in:
App repair completed with errors: Command '['certbot', 'certonly', '--non-interactive', '--text', '--agree-tos', '--register-unsafely-without-email', '--domain', 'myhost.freedombox.rocks', '--authenticator', 'webroot', '--webroot-path', '/var/www/html', '--renew-by-default']' returned non-zero exit status 1. Details
Exception: Command '['certbot', 'certonly', '--non-interactive', '--text', '--agree-tos', '--register-unsafely-without-email', '--domain', 'myhost.freedombox.rocks', '--authenticator', 'webroot', '--webroot-path', '/var/www/html', '--renew-by-default']' returned non-zero exit status 1.
Other notes,
In order to repair the app, I must:
  1. Restart my router (power cycle)
  2. Repair the app (This has succeeded most of the time)
I am able to pass diagnostics and connect to the freedombox using the freedombox.rocks domain name, however, over the next 24 hours, access to the URL will fail, and diagnostics indicate Let’s Encrypt has failed.
It appears the Dynamic DNS did not update. I had to set it manually on the freedombox.rocks ddns website. Any advise to get this to work correctly?
This was actually a router problem. When I updated my router’s vpn settings, I didn’t set a VPN policy to ignore my FreedomBox.
