- Whether your FreedomBox is plugged into a router at home or not (if not, please specify how it is connected to the internet)
- The month and year you bought your kit (feel free to omit if you want to preserve some privacy, but this could be helpful information)
- The version of FreedomBox your are running (available by clicking on the “?” in the top menu → “About”)
- FreedomBox is connected to router, behind NAT and set up with port forwarding.
- I’ve had it for a couple of years. Cannot remember the date.
- As of today I’m on FreedomBox version 23.18. Yesterday, I was on 23.6.2 as I’m running stable and letting the unattended upgrades do the work. (I did change
firewalld.confmanually during the dist-upgrade from Debian 11 to Debian 12).
Hello!
I’ve encountered a problem with my FreedomBox Pioneer Edition and wanted to seek some feedback. On 9 October, my device underwent an update with several packages. Following a scheduled restart on 10 October at 02:00, I noticed all my web-based services became inaccessible.
Interestingly, other services like MiniDLNA, XMPP, SSH, and Samba are running without issues. I’m inclined to believe there might be a change affecting the Apache web server, but I’m not entirely certain.
Has anyone else encountered similar problems with the latest update? I rely heavily on my Radicale server, so any guidance to rectify this issue would be greatly appreciated. I’ll attach logs detailing the installed packages to this post.
unattended-upgrades.log
2023-10-09 06:15:03,369 INFO Starting unattended upgrades script
2023-10-09 06:15:03,438 INFO Allowed origins are: origin=Debian,codename=bookworm,label=Debian, origin=Debian,codename=bookworm,label=Debian-Security, origin=Debian,codename=bookworm-security,label=Debian-Security, o=Debian Backports,a=bookworm-backports,l=Debian Backports
2023-10-09 06:15:03,443 INFO Initial blacklist:
2023-10-09 06:15:03,448 INFO Initial whitelist (not strict):
2023-10-09 06:18:25,077 INFO Packages that will be upgraded: base-files curl dbus dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common dbus-user-session debian-archive-keyring debianutils firewalld firmware-ath9k-htc freedombox freedombox-doc-en freedombox-doc-es ghostscript inetutils-telnet libcups2 libcurl3-gnutls libcurl4 libdbus-1-3 libgs-common libgs10 libgs10-common libgssapi-krb5-2 libhwy1 libk5crypto3 libkrb5-3 libkrb5support0 libldb2 libmariadb3 libnftables1 libnss-myhostname libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libssl3 libsystemd-shared libsystemd0 libudev1 libunbound8 libwbclient0 linux-image-armmp-lpae linux-libc-dev mariadb-client mariadb-client-core mariadb-common mariadb-plugin-provider-bzip2 mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server mariadb-server-core nftables openssh-client openssh-server openssh-sftp-server openssl python3-firewall python3-ldb python3-nftables python3-samba samba samba-common samba-common-bin samba-dsdb-modules samba-libs samba-vfs-modules systemd systemd-sysv systemd-timesyncd telnet udev
2023-10-09 06:18:25,080 INFO Writing dpkg log to /var/log/unattended-upgrades/unattended-upgrades-dpkg.log
2023-10-09 07:23:56,184 INFO All upgrades installed
2023-10-09 07:25:45,321 INFO Packages that were successfully auto-removed: linux-image-6.1.0-11-armmp-lpae
2023-10-09 07:25:45,328 INFO Packages that are kept back:
2023-10-09 07:25:49,620 WARNING Found /var/run/reboot-required, rebooting
2023-10-09 07:25:49,909 WARNING Shutdown msg: b"Reboot scheduled for Tue 2023-10-10 02:00:00 UTC, use 'shutdown -c' to cancel."
2023-10-09 18:30:39,295 INFO Starting unattended upgrades script
2023-10-09 18:30:40,316 INFO Allowed origins are: origin=Debian,codename=bookworm,label=Debian, origin=Debian,codename=bookworm,label=Debian-Security, origin=Debian,codename=bookworm-security,label=Debian-Security, o=Debian Backports,n=bookworm-backports,l=Debian Backports
2023-10-09 18:30:40,320 INFO Initial blacklist:
2023-10-09 18:30:40,323 INFO Initial whitelist (not strict):
2023-10-10 06:43:43,073 INFO Starting unattended upgrades script
2023-10-10 06:43:43,084 INFO Allowed origins are: origin=Debian,codename=bookworm,label=Debian, origin=Debian,codename=bookworm,label=Debian-Security, origin=Debian,codename=bookworm-security,label=Debian-Security, o=Debian Backports,n=bookworm-backports,l=Debian Backports
2023-10-10 06:43:43,088 INFO Initial blacklist:
2023-10-10 06:43:43,091 INFO Initial whitelist (not strict):
2023-10-10 06:44:02,839 INFO Packages that will be upgraded: freedombox freedombox-doc-en freedombox-doc-es
2023-10-10 06:44:02,843 INFO Writing dpkg log to /var/log/unattended-upgrades/unattended-upgrades-dpkg.log
2023-10-10 06:48:47,030 INFO All upgrades installed
I also have the logs for unattended-upgrades-dpkg.log but the file is too long to include in this post. I can add relevant lines on demand.
