FreedomBox newbie here. Followed the Installation Instructions about setting up gnudip DNS and LetsEncrypt certs but LE kept failing to verify ./well-known/acme-challenge. So did a port scan and discovered that my ISP is blocking all ports. I have 20Mbps download / 10 Mpbs upload residential service. ISP offers commercial service so I assume the ports get unblocked for commercial customers but get blocked for residential typical customers. So can’t run any services over the clearnet. Bummer. So, guess I’ll have to buy a PageKite plan and tunnel services. Not sure of the bandwidth of the tunnel versus my current ISP connection to the net. Might be nice to update the Wiki to let others know that they might need to check if their ISP is blocking service ports.
Stll learning my way around the FB. I did update i2p to current version 0.9.48 and installed i2pbote plugin. All’s working well now that I’ve set up tunneling between my laptop and the FB i2prouter. Might be good to update I2P instructions on Wiki. Don’t think all the i2prouter apps will work correctly unless tunneling is set up between Browser and FB so that localhost/app gets mapped to the FB and not the Browser.
