System went down again.
Here is the logs
June 14, 2023
9:54 PM
plinth.service: Failed with result ‘exit-code’.
systemd
14
9:54 PM
pam_ssh_add: Failed adding some keys
cockpit-session
9:45 PM
systemd
91
9:45 PM
fail2ban.service: Failed with result ‘exit-code’.
systemd
9:45 PM
Failed to start firewalld - dynamic firewall daemon.
systemd
9:45 PM
firewalld.service: Failed with result ‘exit-code’.
systemd
9:45 PM
systemd
9:45 PM
Failed to start Entropy Daemon based on the HAVEGE algorithm.
systemd
9:45 PM
haveged.service: Failed with result ‘signal’.
systemd
9:45 PM
haveged.service: Start request repeated too quickly.
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
haveged.service: Main process exited, code=killed, status=31/SYS
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:45 PM
systemd
9:43 PM
pmlogger_daily-poll.timer: Failed with result ‘resources’.
systemd
9:43 PM
pmlogger_daily-poll.timer: Unit to trigger vanished.
systemd
9:38 PM
/lib/systemd/system/pmie_check.service:9: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
systemd
9:38 PM
/lib/systemd/system/pmie_daily.service:8: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
systemd
9:38 PM
/lib/systemd/system/pmlogger_check.service:8: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
systemd
9:38 PM
/lib/systemd/system/pmlogger_daily.service:8: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
systemd
9:38 PM
/lib/systemd/system/pmlogger_daily-poll.service:8: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
systemd
9:38 PM
[2edbe4] <group/member=“Debian-exim”> no available LDAP server found: Server is unavailable: Connection refused
nslcd
2
9:38 PM
[9554fe] <group/member=“openldap”> no available LDAP server found: Server is unavailable: Connection refused
nslcd
9:38 PM
[9554fe] <group/member=“openldap”> no available LDAP server found: Can’t contact LDAP server: Connection refused
nslcd
9:38 PM
[0ea5d1] <group/member=“openldap”> no available LDAP server found: Can’t contact LDAP server: Connection refused
nslcd
9:38 PM
[0ea5d1] <group/member=“openldap”> failed to bind to LDAP server ldapi:///: Can’t contact LDAP server: Connection refused
nslcd
9:37 PM
[9554fe] <group/member=“openldap”> no available LDAP server found, sleeping 1 seconds
nslcd
9:37 PM
[9554fe] <group/member=“openldap”> failed to bind to LDAP server ldapi:///: Can’t contact LDAP server: Connection refused
nslcd
9:37 PM
[0ea5d1] <group/member=“openldap”> no available LDAP server found, sleeping 1 seconds
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
[9554fe] <group/member=“openldap”> ldap_search_ext() failed: Can’t contact LDAP server: Broken pipe
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
nslcd
9:37 PM
[0ea5d1] <group/member=“openldap”> ldap_search_ext() failed: Can’t contact LDAP server: Broken pipe
nslcd
9:35 PM
systemd
9:35 PM
systemd
9:35 PM
systemd
9:35 PM
systemd
9:35 PM
systemd
3:46 PM
Ignoring domain ministrywithcommunity.local for DHCP host name M-1754
dnsmasq-dhcp
24
3:28 PM
cockpit-session
8:08 AM
dnsmasq-dhcp
27
7:48 AM
cockpit-session
12:10 AM
June 14, 2023
10:01 PM
systemd
10:01 PM
systemd
Reboot
I can’t get it up again. I don’t know what to do
Scot
