Installing Zoph
I have tried installing Zoph for the first time. I did not notice Zoph Setup and Use before trying, so I just went ahead.
When I click on “Open the web client”, I have a login page and no matter whether I try the admin user or any other user, it says “[tr] You have entered an incorrect username/password combination”.
Not sure what to do.
Hey! I recalled seeing a similar post a while back. You could give it a try. I hope it solves your issue.
Zoph does not fully integrate with SSO. When you install zoph and click the setup button you made that FB user a zoph admin user. You can try to launch zoph from the user account which invoked zoph setup. From there you can add additional users in the application configuration. You may need to add these users to the zoph group on Freedombox.
Thanks for the hint. I tried with a new browser profile, so that there is nothing in the cache, then I can log in as the admin user.
By the way, to make a basic photo gallery, I just used fgallery on a computer running Trisquel, and then uploaded the generated galleries to a Freedombox share. I like that the interface is super simple, but unfortunately, on a small screen like a mobile phone, the photos take a too limited part of the screen.
